Question about Dryers
Duracraft df 1800
Trying to open it so I can clean it and oil the motor - motor squeals
2 Suggested Answers
skodawabo
  • 40 Answers
SOURCE: I am. Trying to clean a duracraft 1997 but i. Cant get the blade to separate. From the motor
Some of them are not meant to be seperated, if it is, then it should have 2 slots opposite of eachother in the back of the blade where the plastic fan meets the steel rotating bar, or it could just be pressed on and you would have to pull it off with as much equal force all around the circumference of the back of the fan's main part, the entire round part, either way you need at least 3 hands to do the job, so have someone help you or just clean it as good as you can as it is, I don't think it really needs to be that clean aye'? LoL
Posted on Nov 16, 2016
The power wheel on my 1984 Baby Lock serger is frozen. I reduced the number on the wheel but it squealed.
Sounds like it may have seized from dried oil. Probably needs a thorough cleaning and oiling. Continued use could damage the motor.
Dec 21, 2017 | Baby Lock Sewing Machines
How can I stop the squealing noise in the motor on my Sanitaire wide track commercial vacuum? It's making a squealing the minute I turn it on
Is it the motor or the brush roll? Remove the brush roll and belt and see if it still squeals. If not clean or replace the brush roll and get a new belt. Inspect the fan to insure there is not something stuck in it. If it's the motor you can try to clean it, make sure there is not something stuck in the motor causing the noise.
Jan 23, 2017 | Vacuums
Nov 16, 2016 | Duracraft Dryers
Hi, I have a Duracraft commercial model fan high velocity I need motor DM514
did you check already the thermal fuse and capacitor??
Oct 02, 2015 | Duracraft Dryers
How to fix squeal in a Maytag airconditioner
no belt. should be a direct drive motor. most likely bearings in motor going out. you will have to replace motor at some point it will lock up. if it has oil ports you can try oiling to prolong but will eventually stop working.
Aug 30, 2012 | Maytag M6Y18F7A Air Conditioner
Makes a irritating squealing noise most of the time?
In a dehumidifier most squealing noises are related to the fan motor or the fan motor shaft. Following the Owners Manual instructions for removing the unit's cabinet for routine maintenance. Lubricate the fan shaft with some light sewing machine oil or a similar oil. That should solve the annoying squeal. And while you've got the cabinet dismantled, do some routine maintenance, like cleaning the refrigerant coils and any other dust or lint you see.
Hope this helps you. Please let me know. Thanks.
May 06, 2011 | Haier HPAC7M Air Conditioner
Hi, I have a Dell Power Edge 1800 server which has recently failed. It had a loud squealing sound coming from it and had exited to DOS. On Reboot it recognises the 5 drives, but states raid failed. It...
there is a problem with memory, try to open the memory card, clean the existing part of the gold layer with pencil eraser, often appear rust because of heat, after clean up, back in the place
Dec 18, 2017 | Dell PowerEdge 1800 Server
Motor making a squealing sound
First try cleaning the outer part of squealing blades with a soft cloth and try.
If not resolved then, you need to open the case and try replacing the blades.
If the problem is still not resolved, please replace the Iccream maker
Sep 12, 2010 | Rival 8401-M 4 Quart Ice Cream Maker
Our duracraft portable fan is humming and not moving? what is the problem and can it be fixed?
Sounds like the armature needs to be cleaned. Dirt can build up on the ends of the motor shaft that operates the fan and where it is held in place, the dirt can actually stop the fan. I would spray both ends of the motor shaft with WD40 and rotate the fan by hand until it is free. This is the cheapest thing to do in order to try and get the fan running again. The problem may be worse than this, but it is a good place to start.
Sep 06, 2010 | Duracraft DB101 Floor / Box Fan
Dryers Logo
57 people viewed this question
Top Dryers Experts
