Question about Neff H5470 Microwave Oven
Neff combination oven just stopped working
My Neff combination oven/microwave just stopped working as if the power was turned off and will not start again.Checked fuse and there ok, any suggestions? It is about 5 years old.
SOURCE: Neff Microwave
check control circuit and full wiring and connectors.
Posted on Dec 01, 2007
  • 9 Answers
SOURCE: Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Posted on Apr 04, 2008
SOURCE: NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Posted on Jun 08, 2009
  • 228 Answers
SOURCE: Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Posted on Aug 05, 2009
  • 228 Answers
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Posted on Oct 28, 2009
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Neff combination microwave oven
We have had NEFF repair man out again and he replaced the door switchs and this time it is OK.He did say if it was a problem again it will be classed as unrepairable because he thinks it is shorting out on an internal rivet on the bodywork which is inaccesable. fingers crossed it was the door switchs and it dosent blow the main fuse again .thanks for your responce. Simon.
Jul 23, 2008 | Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
NEFF 7871 electrical problems
neff built in microwave cannot open the door
Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Feb 15, 2008 | Microwave Ovens
Neff Microwave
Dec 01, 2007 | Neff H7871N2GB Convection / Microwave Oven
Neff H5470 Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
