Question about Nikon COOLPIX P100 Digital Camera
Zoom does not operate smoothly
Have to bump the zoom control frequently to get lens to telescope fully.
DarrenP
  • 78 Answers
SOURCE: Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Posted on Apr 08, 2008
Roynice152
  • 88 Answers
SOURCE: dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Posted on Jan 09, 2009
pontelemon
  • 531 Answers
SOURCE: Wanting to know if the Nikon D90 has digital zoom
There is no digital zoom in DSLR
Posted on Mar 19, 2009
  • 11967 Answers
SOURCE: Everytime I zoom in or out I get a lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
  • 11967 Answers
SOURCE: Dropped my camera on soft
Posted on Sep 13, 2010
The 18-70mm lens on my Nikon D70 is stuck on zoom. I can't take it back in to take a wider shot. I haven't dropped it or damaged it in any way. Any suggestions?
take the lens off the camera, try to change the zoom on the lens. if it works then your lens is ok. on the front lens mount surface of your d70 there is a small "driver" connection, it is in the lower left of the metal surface . this connects to the socket on the lens when the lens is mounted. by the way, your lens doesn't have this though. if your lens moves then your camera body is the problem. your lens is electrically operated for focus only, it is manually zoomed. if you can't zoom it by hand when removed than your lens is probably broken, many of the parts inside these lenses are quite delicate and won't take much of a bump on the front end to break the inside parts, i know, i have broken a few..hope this helps.
Jan 04, 2011 | Nikon D70s Digital Camera
I have the tz7 and have 2 problems with this. when turning on or off the lens cover takes ages to open or close sometimes you have to help it and use your finger to open it!the other is when operating the...
It is normal these things. You can switch it off and then charge it fully and then you can see whether the problems is still there. If this does not help then you have to go to someone who repairs camera.Do not forget to vote for me it is very important
Sep 13, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Top control touchpad not working plus zoom extending.
Its problem of that loading flap (technical name is control switch block) and requires replacement.
control switch block is included play-stop-rew-ff-eject etc switches including zoom-wide switch.
Jun 21, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Olympus C-3000 Zoom telescoping lens problem
The small gears that link the viewfinder and lens may be out of sync. If you are a technical person, you can remove the frontcover, first taking off the topcover, (one screw is hidden under the mode dial). Power up the camera and remove the batteries when the lens is fully extended. BE CAREFUL NOT TO TOUCH THE CAPACITOR! Gently lift the viewfinder and move the viewfinder gear one tooth. It will probably only move one way. Put the batteries back in and try the lens. If this does not solve the problem, you may need to replace the lens or viewfinder.
Mar 20, 2007 | Olympus C-3000 Zoom Digital Camera
Nikon COOLPIX P100 Digital Camera Logo
15 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
