Question about Transmission & Drivetrain for Ford Transit Connect
Windstar transmission it slips starting out and when u go up hills
  • Ford Master
  • 5,784 Answers
Could be TPs sensor..
Posted on May 09, 2013
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
My transmission just started slipping and the fluid leaking on my 99 windstar van
You have a transmission leak,and may be it is low,check the fluid level.
Dec 20, 2009 | 1999 Ford Windstar
2002 Windstar hesitates under power. Difficult to climb hills but if you downshift to second you have more power but still doesn't seem right
Pull your transmission dip stick smell the fluid,if it smells nasty and burnt,have your transmission serviced.
The tool for all automatic transmissions is CLEAN TRANSMISSION FLUID!
Aug 10, 2009 | 2002 Ford Windstar Cargo
Transmission problems
I would take it back to the rebuilder. Perhaps it just requires adjustmnet.
Nov 21, 2008 | 1996 Ford Windstar
sorry the trannys gone DOA
check you options
Jul 08, 2008 | 1999 Ford Windstar
Transmission & Drivetrain for Ford Transit Connect Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
