Question about Engines & Components for Alfa Romeo 156
Remove Wipers how to remove wiper arms
  • 5,648 Answers
I thing is only one screw holding.
Posted on May 09, 2013
How to correct wipers on ford fiesta finesse
there should be a nut at the bottom of the wiper arm possibly a plastic cover over the nut remove and remove the nuts while the nuts are removed grab wiwiper at the top and try to jiggle of stud at the bottom sometimes it helps to move wiper arm so it hinges or wiper arm is sticking up ,once removed set the wipers mabey 2 inches above the bottom of the window and tighten nuts
Feb 17, 2013 | Ford F Cars & Trucks
How to replace the wiper motor on a 1994 volkswagon golf
The wiper motor on a Volkswagen is an electric motor connected through a drive linkage to the wiper arms. Windshield wipers are an integral feature for operating a motor vehicle safely. If your wipers are not functioning, or seem to lack the speed or power they used to have, the wiper motor should be removed and replaced immediately
Location
  • The wiper motor on a Volkswagen is located directly underneath the plastic cowl cover. The cowl cover is located directly below the windshield.
Removal
  • Begin by removing the wiper arms by prying off the covers at the base of the arms and removing the nuts that secure the arms to the drive shafts. Label the passenger and driver arms so they can be installed in the same positions. They are not interchangeable. Remove the rubber hood to cowl weather seal. Unscrew the plastic fasteners from the driver's side of the cowl cover, then remove this half of the cover. Remove the fasteners from the passenger's side cowl cover and remove this half of the cover. Disconnect the windshield wiper motor wiring harness by separating the plastic wiring connector. Remove the three bolts that secure the wiper motor to the vehicle's body. Pull the motor slightly away from the body, then remove the nut that connects the motor shaft to wiper linkage. Remove the motor.
Installation
  • Place the new wiper motor into position in the cowl and reconnect it to the wiper arm linkage. Then reinstall the three retaining bolts. Reconnect the plastic wiring connector to the wiper motor wiring harness. Place the cowl covers into position below the windshield and reinstall the plastic fasteners that retain them. Reinstall the rubber hood to the cowl weather seal. Reinstall the wiper arms in the same position you removed them from, along with the wiper arm retaining nuts and lower wiper arm covers. Turn the windshield wipers on and test for proper operation. If the wiper blades slap against the bodywork surrounding the windshield, loosen the nuts that connect the wiper arms to the shafts and adjust.
More Read: OBD2 car diagnostic tool
Aug 06, 2012 | 1994 Volkswagen Golf
How do I change wiper blades 2001 Chevy blazer
Open the cap at the end of the windshield wiper arm at the cowl of the Blazer. This will reveal the bolt that secures the wiper arm to the wiper linkage.
Unbolt the wiper arm using a 3/8-inch ratchet and socket. Place the bolt to the side, as you will reuse it later.
Pull the wiper arm up at the blade so that the blade of the wiper is pointing into the air. Then pull at the base of the arm, wiggling it slightly. It's a keyed gear, so it may take a little bit of workunderlined.png?1 to break it free, but with the right amount of wiggling, it will disengage.
Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4pQJ39h
  • 3 Pull the wiper arm up at the blade so that the blade of the wiper is pointing into the air. Then pull at the base of the arm, wiggling it slightly. It's a keyed gear, so it may take a little bit of workunderlined.png?1 to break it free, but with the right amount of wiggling, it will disengage.
  • Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4pJlPaV
  • 2 Unbolt the wiper arm using a 3/8-inch ratchet and socket. Place the bolt to the side, as you will reuse it later.
  • Read more: How to Remove Chevy Blazer Windshield Wipers ' eHow.com http://www.ehow.com/how_6177302_remove-chevy-blazer-windshield-wipers.html#ixzz1B4p1UYyB
    Jan 15, 2011 | 2001 Chevrolet Blazer
    I need to adjust the wiper arm on a 1997 suburban, it hits the side of the window.
    Wiper Arm & Blade (Front) Removal & Installation Wiper Blade To Remove:
    1. Turn ignition switch to ACCY position.
    2. Turn wiper switch to PULSE position and turn ignition OFF when wipers are stopped in the innerwipe position.
    3. Push the wiper blade clip button IN and remove wiper blade from wiper arm.
    To Install:
    1. Insert wiper arm hook through opening in wiper blade.
    2. Place wiper blade pivot in the inside radius of wiper arm hook.
    3. Pull on wiper blade pivot into hook until it locks into place.
    4. Check wipers for proper operation.
    Wiper Arm To Remove:
    NOTE: Mark position of wiper blade on windshield to ensure proper position upon reassembly.
    1. Remove washer hose.
    2. Lift wiper arm from windshield and use a screwdriver to disengage retaining latch.
    3. Remove wiper arm from shaft.
    To Install:
    1. Place wiper arm on shaft so that wiper arm aligns with marks placed on windshield.
    2. Press arm assembly on shaft and push retaining latch IN.
    3. Connect washer hose.
    4. Remove windshield markings and check wipers for proper operation.
    Oct 26, 2010 | Chevrolet Suburban 1500 Cars & Trucks
    How do I replace a rear wiper arm on a Audi Q7
    LOOSEN AND REMOVE WIPER ARM NUT.THEN REMOVE WIPER ARM BY ROCKING MOTION SHOULD COME OFF.
    Oct 02, 2010 | 2007 Audi Q7 4.2 FSI
    Driver side wiper dont work
    vehicle may have a stripped wiper arm.( remove wiper arm,turn on wipers & see if splined knob is moving ),if so turn off wipers & replace wiper arm.or if knob does not move then have to remove cowel & check linkage to wiper transmission!
    Sep 13, 2010 | 1992 Dodge Caravan
    Windshield wipers will not move. Arms from motor
    Hello
    The windshield wiper linkage comes as an assembly. The assembly comes with the two rotating splines that the wiper arms attach to. you must remove wiper arms. Remove cowl trim and remove bolts that hold the pivot points to the body. The new linkage that snaps to the wiper motor should come with a new retaining clip. You have to fish the linkage assembly through the access holes in the body by un bolting the wiper motor.
    Dec 19, 2009 | 2002 Ford E350
    2000 Saturn LS, windshield wipers park in the middle of the windshield. How can I fix this?
    The wipers are parking in the middle because the timing mechanism is off. Once they start doing this it seems to continue to happen so the 1st suggestion is to replace the wiper motor. If U don't want to spend the $ right now it's a pretty easy fix to reset the timing. Park the wipers & remove the wiper arms. Then remove the plastic cowling that covers the wiper motor & the motor assembly. Turn the wiper assembly over without turning the motor. Remove the nut on the arm of the motor. Repostion the arm pointing away from the closet wiper directly inline with the short arm. reassemble.
    Oct 24, 2009 | 2000 Saturn Ls 4dr Sedan
    Snow caused wipers
    You'll have to have arm removed and repositioned. If there is a little cap at end where it mounts, snap it up , remove nut, and wiggle arm upward, until off, put wipers in park, set arm back on in proper position & tighten nut. If no nut, there should be a clip on side that you pry out and pull arm off same way. If not successful, a local garage or bodyshop should do it for you for minimal or no charge. Hopefully splines inside arm aren't stripped off. Clean all good before re-install.
    Mar 03, 2009 | 2000 Ford Expedition
    Cant take off the windsheild wipers
    Here is the procedure to remove the wiper motor. It says to remove wipers by removing the nut covers then remove the wiper nuts. Is this what your talking about?
    If your talking about the wiper arms they just pop off at the swivel.
    Use this link for info on removing blade assy.
    http://www.autozone.com/az/cds/en_us/0900823d/80/04/f8/26/0900823d8004f826/repairInfoPages.htm
    Wiper Motor
    1. Before servicing the vehicle, refer to the Precautions section.
    2. Park the wiper pivot arms in the highest position on the glass.
    3. Disconnect the battery ground cable.
    4. Remove the wiper pivot arm nut covers.
    5. Remove the nuts and the wiper pivot arms.
    6. Remove the cowl top vent panels.
    7. Remove the four bolts, wiper mounting arm and wiper pivot shaft assembly.
    8. Disconnect the electrical connector.
    9. Remove the bolt and the windshield wiper motor operating arm from the motor.
    10. Remove the three bolts and remove the windshield wiper motor.
    11. To install, reverse the removal procedure.
    Jan 28, 2009 | 2005 Ford Taurus
    Vehicle Parts & Accessories Logo
    76 people viewed this question
    Top Alfa Romeo Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you an Alfa Romeo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
