Question about LG WM-1480FHD Front Load Washer
LG WM-1480FHD Bearings help.......please
Removed back cover to reveal what looks like a wheel hub, removed centre nut to reveal the bearings. As these have a large rust stain, I have just taken delivery of new bearings. But now i cant remove the large back that has two rings of bolts.. is the back plate welded on ?? How do i get the bearings out please...........HELP CREEKY
  • LG Master
  • 909 Answers
ACTUALLY CREEKY WITH BEARING AND SEAL REMOVAL, YOU NEED CERTAIN TOOLS AND KNOWLAGE CONCERNING THE PROCEEDURE. TO DO IT AS A D.I.Y.REPAIR ONCE OFF IS POSSIBLY NOT VIABLE DUE TO DEFINITE DAMAGE WHICH WILL OCCUR. SUGGEST A TECH.
Posted on Aug 17, 2007
SOURCE:
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
How to replace a rear wheel bearing hub?
Remove brake components, remove centre cover to expose securing nut, remove nut and using a 3 jaw puller remove the bearing and hub. The inner race will remain on the spindle and will need to be cut off being carefully not to cut the spindle. I use a cutting torch to achieve this. ER the spindle cool befor installing the new bearing/hub assy. Don't forget to torque the nut to spec. I can't remember offhand what it is but if you over tighten it the braring life will be reduced. Also use a new nut as they are one time use and may loosen over time if reused.
Feb 22, 2015 | 2002 Volkswagen Jetta TDI
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Holden instruction manual
telling people which holden from which year might be useful.
in general terms you usually pop off a cover in the centre to reveal a large castellated nut with a cotter pin. Remove pin , remove nut, this usually gives you access to the bearings. Before all that you will have had to do something with the brakes depending on what model/year you are talking about.
Sep 02, 2014 | Cars & Trucks
How to replace rear wheel bearings on a 2000 cougar?
Hi,welcome to fixya.
The rear wheel bearings are not adjustable. If the bearings make noise or become loose, they must be replaced.
With Drum Brakes
NOTE The wheel bearings are contained within the wheel hub and must be replaced as an assembly.
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the wheel and tire assembly.
  4. Remove the anti-lock sensor retaining bolt and remove the sensor.
  5. Remove the brake drum retainer and the brake drum.
  6. Remove the hub retaining nut dust cover.
    NOTE Do not use an impact gun to remove the hub retainer nut.
    0996b43f80232353.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using suitable tools loosen and . . .
    0996b43f80232351.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. . . . remove the hub retaining nut dust cover
  7. Remove the wheel hub retainer nut.
    0996b43f8023234f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using suitable tools, loosen and . . .
    0996b43f80232352.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. . . . remove the hub retaining nut
  8. Slide the hub and bearing assembly off of the spindle.
    0996b43f80232350.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Carefully slide the hub and bearing assembly off of the spindle
To install:
  1. Reinstall the hub and bearing assembly to the spindle.
  2. Reinstall the hub retainer nut. Tighten the retainer nut to 170-192 ft. lbs. (230-260 Nm).
    WARNING Do not use an impact gun to tighten the hub retainer nut, otherwise the bearings may be damaged.
  3. Install the hub retaining nut dust cover.
  4. Reinstall the brake drum.
  5. Check the brake shoes for proper adjustment.
  6. Reinstall the anti-lock sensor and the retaining bolt. Tighten the retaining bolt to 7-8 ft. lbs. (9-11 Nm).
  7. Reinstall the wheel and tire assembly. Tighten the wheel nuts to 62 ft. lbs. (85 Nm).
  8. Lower the vehicle until the wheels are supporting the vehicles weight. This will properly load the suspension.
  9. Tighten the spindle-to-control arm bolt to 52-79 ft. lbs. (70-98 Nm).
  10. Tighten the tie rod-to-spindle bolt to 75-102 ft. lbs. (102-135 Nm).
  11. Finish lowering the vehicle.
Road test the vehicle and check for proper operation.
Thank You for using fixya........iluv2fish........Ray........
Jul 16, 2010 | 2000 Mercury Cougar
How hard is to change front bearings and special tools??
No special tools, not hard, get the parts, rubber gloves, can of grease, and a couple hours time, turn off the cell fone. Pull the wheel, remove dust cover, pull cotter pin, remove brake caliper, hang from wire, remove nut on spindle, bump rotor with rubber mallet, the bearings should pop out, pull the hub off, knock out the inner seal and bearings, replace with new bearing packed with grease, replace seal, put hub back on, put on outer bearing, packed with grease, washer, nut, tighten up snug by hand, then back off so wheel spins free and doesn't rock, put in cotter pin, dust cover, caliper, tighten up, your all set. Too tight will burn up bearings, too loose and you will hear it rocking back and forth. Hope this helps.
May 03, 2010 | 1996 Ford Windstar
How tight should the nut be on the front wheel bearings for a 2006 f250 two wheel drive.
  1. Before servicing the vehicle, refer to the Precautions Section.
  3. Support the front end.
  4. Remove the wheel cover, if equipped.
  5. Remove the grease cap.
    NOTE Check the wheel bearings for sufficient grease.
  6. Remove the cotter pin and retaining washer. Back off the spindle nut. Discard the cotter pin.
  7. Adjust the wheel bearings as follows:
    1. Tighten the spindle nut to 30 ft. lbs. (40 Nm) while rotating the brake disc clockwise to seat the wheel bearings.
    2. Back off the nut 2 full turns.
    3. While rotating the disc counterclockwise, tighten the nut to 17-24 ft. lbs. (23-34 Nm).
    4. Back off the spindle nut about 1 / 2 turn.
    5. Tighten the spindle nut to 17 inch lbs. (2 Nm).
  8. Install the retaining washer so the castellations are aligned with the cotter pin hole. Install a new cotter pin.
  9. Check the wheel and tire assembly for proper rotation, then install the grease cap. If the wheel still does not rotate properly, inspect and clean or replace the wheel bearings and cups.
  10. Install the wheel cover, if equipped.
  11. Lower the vehicle.
  12. Road test the vehicle and check for proper operation.
To check the wheel bearing adjustment, raise the front of the vehicle. Grasp the tire at the sides, and alternately push inward and pull outward on the tire. If any looseness is felt, adjust the front wheel bearings as follows.
  2. Remove the hub cap from the hub.
  3. Remove the cotter pin and the castellated nut.
  4. While rotating the wheel, tighten the adjusting nut to 21 ft. lbs. (28 Nm) to seat the bearings.
  5. Back off the adjusting nut until loose (120-180 degrees).
  6. While rotating the wheel, tighten the adjusting nut to 18 inch lbs. (2Nm). Torque required to rotate the hub should be 18 inch lbs. (2 Nm).
  7. Install the castellated nut and insert a new cotter pin.
  8. Install the hub cap
Mar 06, 2010 | 2006 Ford F-250 Super Duty
Trying to remove rear brake drum cover,have already adjusted star wheel and still won't remove. what am i doing wrong? for a 93 plymouth grand voyager
  1. Raise and support the rear of the vehicle on jackstands.
  2. Remove the wheels and tire assemblies.
  3. Remove the brake shoe adjusting slot cover from the rear of backing plate.
  4. Insert a thin tool through the adjusting slot and hold the adjusting lever away from the star wheel.
  5. Insert an adjusting tool and back off the star wheel by prying downward with the tool.
  6. Remove the center hub dust cover, nut, washer, brake drum, hub and wheel bearings.
To install:
  1. Inspect the brake lining and drum for wear.
  2. Inspect the wheel cylinder for leakage. Service as required.
  3. Remove, clean, inspect and repack the wheel bearings.
  4. Install the brake drum and tighten the hub nut to 20-25 ft. lbs. (27-34 Nm), then back off the nut until bearing pressure is released.
  5. Retighten the nut finger tight, align the cotter pin hole and install the cotter pin.
  6. Adjust the rear brakes as described in the beginning of this section.
Removing the rear drum adjusting hole cover plug
Oct 07, 2009 | 1993 Plymouth Grand Voyager
I need instructions on how to replace rear wheel bearings on my 1994 Honda Civic
Bearings are pressed into the hubs...much easier, faster and economical (if you don't have a press) to replace the complete bearing/hub assembly, no pressing is needed, since bearings are already pressed into the new hubs. Cost..aprox, 60 buxs each.
Here are the steps for the rear replacement...
Loosen the lug nuts on a rear wheel. 2) Chock the wheels and jack the rear of the car on the side with the lug nuts that you just loosened. 3) Remove the wheel by removing the lug nuts. 4) Pry open the dust cap covering the center of the axle/spindle. A small screwdriver tapped into the space between the hub and dust cap will work well for this. 5) With the dust cap now removed, use a thin center punch to straighten the little dent in the rim of the spindle nut so that you will be able to turn it freely in the next step. 6) Use a 32mm socket and a large breaker-bar to loosen the spindle nut. Unscrew the nut all the way and place it in a clean, safe area. 7) You should now be able to slide the hub/bearing assembly from the shaft. 8) Installation is the reverse of removal. Use plenty of high-temperature wheel bearing grease on all surfaces before you mount the replacement hub assembly.
IMPORTANT: Torque the spindle nut to 134 ft/lbs....(per manual specs)
When reinstalling the dust caps, tap them gently into place to avoid denting them...Install wheels, jack her down and pat yourself on the back...job complete.
Good luck..hope this will fixya up...please take time to leave me a fixya rateing...
May 23, 2009 | 1994 Honda Civic
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
LG WM-1480FHD Front Load Washer Logo
520 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
