Question about Honeywell PRO 4000 5-2 Day Programmable Thermostat - TH4110D1007
Thermostat th4110d won't run on cool setting
Thermostat won't change from heat to cool.
Go into the programing and change the reversing valve setting to the next number.
Jun 15, 2013 | Heating & Cooling
Attic fan won't turn off
faulty thermostat switch
Jul 15, 2017 | Broan-NuTone Dryers
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have a pro th4000 series honeywell programmable thermostat and its for system type th4110d electric heat with ac how do i set the thermostat to drop a few degrees before the heat turns on right now i got...
this thermostat does not have a deadband option, the only other thing you can do is set the program for a different temp. the cycles per hour just restrict how many times the unit comes on.
Dec 15, 2009 | Coleman Heating & Cooling
Honeywell PRO 4000 5-2 Day Programmable Thermostat - TH4110D1007 Logo
37 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
