Question about Troy Bilt 175HP Manual 42" Riding Mower
Replace fuse when engaged the fuse blows and motor shuts down
    Sergeant:
  • 417 Answers
You may be putting in a fuse that has too low of an amperage. Check the manual and put in the proper size. if they still keep blowing, there is a short or a wire grounding somewhere.
Posted on Jun 10, 2013
I have a 2001 F150 king ranch 4x4 that blows a fuse while selecting 4 wheel drive
What fuse blows ? The four wheel drive switch is a input to the GEM - generic electronic control module , low voltage ! There are a few different relays, a shift motor on the transfer case . There could be DTC'S - diagnostic trouble codes stored in the GEM module . You can find free wiring diagrams at http://www.bbbind.com/free_tsb.html Do you know how to do basic automotive electrical testing ? When you turn the switch to engage the 4X4 , the GEM see's that input an then energizes a relay to engage the 4X4 . Knowing which fuse blows would cut down on the guess work !
Dec 02, 2016 | Cars & Trucks
04' GMC Sierra quadrasteer, trec fuse 30a blows when trying to engage 4wd. I replace fuse, start truck and 4wd auto is lit up but if I press 2h, 4h, or 4 low it blows. What should I do or look for?
Wild guess here, had a similar problem on my 2000 4x4 blazer, has an electric motor on transfure case to swith it into 2h, 4h, and 4l, would blow the fuse every time when switching, did is to replace the motor. Just confirm your fuse that is blowing feeds that.
Oct 21, 2016 | 2004 GMC Sierra
Lx173 John Deere wont start. starter motor will not run to start eng you hear only solenoid engaging starter drive. have tested motor on bench. started blowing fuse since solenoid replaced.
You may have a bad key switch or you have a short in the wiring somewhere. Also check the Magneto's for proper gap. If they are loose they will stick to the flywheel and prevent motor from turning and could blow fuse.
Oct 21, 2016 | John Deere Garden
How to repair motor
If the motor is running then the fault must be with either the clutch on top of the motor or the blade clutch it engages with.
Aug 30, 2014 | Breville BBL600XL. 5-Speed Blender
Why is our SPE150 KH is blowing fuses, gets started runs awhile then it blows a fuse. does any one have any ideas?
Have you checked if anything is wrapped around the blade shaft? Anything that gets in there and causes the motor shaft to slow down will cause the motor to draw more current and trip a breaker. Does the unit have an overheat sensor on the motor (may are built in..check the manual) If the cooling slots are too dirty the overheat sensor shuts down the motor to keep it from burning itself out.
Jul 29, 2014 | Garden
Starter just spins after ignition wire replaces - no fire
Sounds like you have the starter wires hooked up wrong and to continuous power. If starter shuts off with the key now, but wont engage the motor, you may need shims so that the starter drive lines up with the motors fly wheel
Apr 09, 2014 | 1995 Chrysler LHS
Engage blades engine shuts down
if you removed the seat and then placed a fuse in the plug for the saftey switch and then started having this issue . with my experience with the safty switches on the seats most are open as not connected to make a circut when your sitting on the seat or pressure is applied to the seat . try removing the fuse and attempting to start mowing or least ingauge the blades and that should fix your issue ... when removing the origonal seat you just left that curcut open so it can not close and make connection when you get off the seat . so you should be fine after removing the fuse from the socket .. happy mowing
Nov 07, 2011 | Craftsman Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
ABS light went on while driving and noise stays on after ignition is turned off.
There is a relay inside of the ABS motor housing that can stay engaged making the motor run continuously without the key in the run position. If this is the problem the only fix is to replace the Brake Pressure Modulator Valve assembly. You may also may need to replace the Control Module that is attached to it.
The motor can be unplugged from the module and will shut off. The ABS light will stay on until it if fixed properly. The other way to shut down the motor is to remove the ABS fuse in the underhood fuse box.
The ABS module and BPMV are expensive and the brakes will have to be bled. Junk yard parts can be cheaper if your capable to replace them.
Jul 27, 2010 | 2002 Chevrolet Tahoe
My washing machine keeps shutting down and blowing a fuse.
You must have a short circuit ,try disconnecting things start with the heater element, disconnect one wire see if it still blows...next try motor plug, until the fault clears at least this tells you what the problem part is.....
Apr 11, 2010 | LG WM-2077C Front Load Washer
Troy Bilt 175HP Manual 42" Riding Mower Logo
82 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
