Question about Health & Beauty
Battery wont charge
Ew 36 mobility scooter
    Welcome Back:
    Visited the website for 2 consecutive days.
You may know this already, but if you don't charge it at least once a week, the battery ends up being worthless. So it's really about the battery. Hope this helps.
Posted on May 10, 2013
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
gewiz
  • 1263 Answers
SOURCE: rover three wheel mobility scooter full charge
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Posted on Jul 24, 2009
  • 103 Answers
SOURCE: only one battery charging on mobility scooter
If only one battery is charging than you only have one good battery. You should have BOTH batteries load tested. If you have to replace one than you should replace both. If you only replace one battery then it will shorten the life of the new one.
Posted on Nov 10, 2009
  • 61 Answers
SOURCE: Looking for a User Manual for a Days Medical
Cant help with the manual but the solution to your problem will probably be duff batteries. This is most likely but it could lie with a number of other things. May be charger but probably unlikely. If not batteries, I think this may be the electromagnetic brake not releasing properly and dragging the batteries down. You can usually smell if they are not releasing as they get VERY hot and smell similar to a burnt clutch on a car. The brake is attached to the end of the motor. If you can hear a click from the brake when the throttle is pressed, it might be ok (although it should really be tested with a multimeter for resistance and voltage as the fault could lie in the wiring loom). Also, if its not releasing correctly, i may have turned a shade of blue due to heat build up. Other problems could be high resistance within the motor or transaxle. Would need to perform a Motor Draw test to determine which, if any, of these are at fault.
Posted on Mar 18, 2010
How to change a rear wheel on my ew 36 mobility scooter?
Put the scooter up on blocks tall enough to raise the wheel completely off the ground. In the center of the wheel there is a removable cover much like a hub cap on a car. Remove this cover to expose the axle nut and remove the nut with a properly sized socket wrench. Reversing the procedure for installing the new wheel.
Jul 28, 2017 | Health & Beauty
When I turn on my scooter it is making a clicking sound and doesn't start
Hi have U charged the batteries ....if there is any doubt about the condition of them buy a battery load tester of E/BAY cost approx $36 ..this will give U an accurate Reading on There condition Cheers
Nov 04, 2016 | Health & Beauty
CAN i CHARGE A 36 VOLT BATTERY WITH A 24 VOLT CHARGER?
No of course not.
The charger has to be the same as the battery it is charging. On BIG batteries, it also has to have the power to handle the higher amps as well.
  • 36 Battery Charger Volts - 36 Battery Charger Volts - Deals! Ad · www.HomeGardenPro.com 36 Battery Charger Volts - Deals! Your Home, Your Style - Redefined.
    Handpicked Collections · Great Deals - Low Prices
  • 36 Volts Battery Charger ' Calibex.com Ad · www.Calibex.com/Electronics Cheap Prices and Huge Selection 36 Volts Battery Charger on Sale!
  • 36 volt battery charger in Batteries & Chargers ' eBay www.ebay.ca > Search > 36 volt battery charger Find 36 volt battery charger and 36 volt battery from a vast selection of Batteries & Chargers. Get great deals on eBay!
  • 36 Volt Battery Charger ' eBay ebay.com Find great deals on eBay for 36 Volt Battery Charger in Forklift Batteries and Chargers. Shop with confidence.
  • 36 Volt Battery Chargers ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Chargers in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Chargers - Electric Scooter Parts www.electricscooterparts.com/36vchargers.html 36 Volt Battery Chargers for Electric Scooter, Bicycle, Pocket Bikes, and Go-Karts. We have 36 Volt (36V) battery chargers in stock.
  • 36 Volt Battery Charger ' Kijiji: Free Classifieds in ... www.kijiji.ca > Ontario Find 36 Volt Battery Charger in Canada ' Visit Kijiji Classifieds to buy, sell, or trade almost anything! Used cars, pets, jobs, services, electronics, homes, boats ...
  • 36 Volt Battery Charger eBay
    Sep 20, 2016 | Health & Beauty
    How do I recharge the battery tried replaceing the fuses but it will not charge
    the charging fuse on these is internal inside the battery box
    1 carry out a continuity test in this blade fuse for open circuit
    2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
    3.make sure your charger is the correct one for this scooter
    as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
    Jan 15, 2015 | Pride Mobility Products GoGo Elite...
    My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
    make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
    Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
    Mobility scooter goes slow
    driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
    Jan 21, 2012 | Health & Beauty
    Electric 3 wheeled mobility scooter wont move
    Look at the rear of the scooter, make sure the Free Wheel lever is engaged
    Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
    Battery full on Ascot Mobility scooter but wont start
    mcdevito75 here, Double chek the connection at the battery and motor.
    Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
    Health & Beauty Logo
    741 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
