I have an machines CPU and it wantstart - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
EMachines doesn't make CPU's
Intel, AMD, and VIA; does
Doesn't start as in what?
1) Does not turn on? (Power supply does not turn on)
2) Windows does not come up?
Also post the model number.
(Back of computer, or up on side of computer tower)
Post back in a Comment
Regards,
joecoolvette
Posted on May 04, 2013
99tahoe wantstart unless gas is poured in throttle body
check your car fuel system from the fuel pump to your car injectors. That mean is no fuel go to the engine
Jul 20, 2013 | Cars & Trucks
Wantstart
sound like alternator failure but check for loose or damaged drive belt.
Oct 23, 2012 | 1995 Buick Riviera
My eMachine Model W2686 CPU will not turn on. Is
it's not issue of CPU problem 1st chack your CPU Fan is working or not then only u can find the pro
Apr 13, 2010 | E-Machines eMachines W2686 PC Desktop
Gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Jan 10, 2010 | Intel Motherboard
Computer does not fire up. I do have steady green light on power supply. All motherboard connections appear to be tight.I have come home before to a beeping noise in the past. After resetting the machine...
That beeping noise may be due to over heating.
Most machines today have a temperature setting that will turn the machine off once the temperature reaches a certain point.
Safety feature to avoid damaging your cpu and components.
The shut down and restarting allows the CPU to cool down briefly.
Thus allowing you to start the machine again. Usually it will shut down again once the temperature threshold is again reached.
Good test is let the machine sit for 30 min. If it immediately starts up and shuts down a few minutes later. Heat build is usually the problem.
Typically this is due to heat sink or Fan on the computer CPU.
Check to be sure both are connected to the CPU and functioning.
If you have a fan on top of the heat sink above the CPU. Make sure it is working correctly. Dust build up over time will eventually kill the fan bearings or reduce airflow. Heat sink can and will become clogged with dust also. Replacement fans are easy to find. Heat sinks are even easier to clean.
Depending on your machine and CPU position replacing the fan can be a challenge. But can be done in a few minutes with minimum tools.
Each bios has different post codes and it is difficult to tell what is happening with out knowing the bios of your particular machine. Listen for the beeps and check your computer manual.
You can also google for this. Here is a web site that lists a few bios P.O.S.T codes.
http://www.computerhope.com/beep.htm
Once you know the beep sequence you can look it up. Usually points to the problem and you can go from there.
Oct 06, 2009 | Computers & Internet
I get 3 beeps and no video on my gateway desktop
The beeps usually meen that the memory is either incorrect or not inserted correctly. Try removing the new memory and go back to the original configuration. Though not recommended, putting the memory in while still plugged up should not be the problem.
Sep 01, 2009 | Computers & Internet
Friend has a Emachine T1862 that won't start
May be the CPU fan is going bad. I hope it is that simple.
Dec 14, 2008 | E-Machines Computers & Internet
Problem with the CPU cooling fan...!! :-(
Dear ARGHYA,
welll i can understand this, for this you can apply the Heatsink Grease between CPU and CPUFAN . it will help to reduce the CPU Temprature.
Cheerup
Mar 04, 2008 | Computers & Internet
Does the motherboard for the model w3107 e machine with the sempron cpu processor driver upgrade deemed compatiable
The AMD Sempron 3100+ Processor is the highestspeed CPU you can run in the W3107 E-machine. No there are no drivers that need to enabled.The system bios sets up the cpu. Did you install this CPU?
Your E-machine:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3107
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
