Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
How to add oil to rear end - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
  • 43 Answers
Most likely it is a sealed unit so you will not be able to check, add or replace fluid.
Posted on Oct 18, 2013
How to put gear oil in..
The only place to put gear oil is in the "pumpkin". Otherwise called the rear-end.
To do so, I recommend driving the car backwards onto two ramps to raise the rear end up in the air, this also tilts the car forward.
Between the rear wheels, in the center of the axle, is a large metal container of gears and gear oil.
There should be a large hex-headed bolt less than half-way from the bottom to the top on the rear, facing your back bumper.
This is where the gear oil goes in, but after you take the bolt out, before you add any oil, stick your finger into the hole and try to feel the oil level.
If you can feel it, you don't need any more gear oil to be added.
Jan 21, 2013 | 1998 Ford Expedition
I have a Craftsman 17.5 hp 42 in.cut riding lawn mower that I've had for about 5 years now, and the rear end is starting to make a whinning sound..How do I grease, or oil the rear end?
It a sealed unit. No service needed. They said call service provider. You tear it apart, if you want. Remove axle from mower. The case unbolt in two pieces>
May 08, 2012 | Craftsman Garden
Cant find where to add new oil to the rear end. found the plug down low to see if you have oil in rear end but see no place to add new oil!
You have to add the new fluid through that same inspection hole, until it starts to overflow. It is about halfway up the middle of the rear diff, exactly where the oil level has to be.
Feb 14, 2011 | Jeep Grand Cherokee Cars & Trucks
I need to grease or oil my rear axel on my 1983 silverado and don't know where to put the oil or grease... It's a automatic
It depends on which rear end is in your truck. There may be a plug about half way up the back cover on the differential, or it may be on the front passenger side of the rear end. The plug will come out using a 3/8 drive ratchet. Make sure you use a screwdriver or something to clean the hole out before you try to turn it. If you don't get it clean then the ratchet will slip and round the corners of the plug and then it isn't coming out.
Add your oil until it starts to leak out the plug hole. Then it is full and put the plug back in. You need to know if you have a limited slip differential or not. Limited slip takes special oil. Regular rear ends take 80-90 gear oil. Hope this helps.
Oct 28, 2010 | 1983 Chevrolet Silverado
Need to find out how to add oil or check the oil in the rear end of a 2000 GMC gimmy
Hello, there is a fill pluf on the passenger side of rear end to check the fluid level and to add fluid. here is some help on this.
  • Remove the rear axle fill plug.
  • Inspect the lubricant level. Specification
    The lubricant level should be between 0-10 mm (0-0.4 in) below the fill plug opening.
  • If the level is low, add lubricant until the level is even with the bottom edge of the fill plug opening
    Sep 20, 2010 | GMC Jimmy Cars & Trucks
    Rear end is poping when i make left turns.
    totally clean out your rear end,taking back cover off and spray with cleaner and air hose. reinstall with new gasket glue and add new oil, but put in 2 bottles of anti slip differential oil, then top with gear oil. make several figure 8 's til rear end fully distributes oil thru out rear end. if rear end is dirty you may have to repeat this action after5000 km. diff slip oil can be purchased at dealer
    May 31, 2010 | 2003 Ford Explorer
    Do i need to add any additive to my rear end when change the oil? diesel 2500
    You don't have too, but lucas oil is a fantastic addiditive that will last much longer. I add to to rear end, transfer case and oil. They also make a tranny additive as well.
    May 13, 2010 | 1999 Dodge Ram
    There is a clanging noise when i put it in gear and can hear it while driving is it the rear end or universal joint
    Check rear-end fluid level and play in rear pinion gear.
    Check universal joints for play. If play is in pinion gear change rear end fluid and add a full bottle of LUCAS oil stabilizer, will quiet rear end noise.
    Feb 01, 2010 | 2000 Chevrolet Silverado 1500
    I HAVE PROBLEME OF GESTETNER DSC224 ERROR COPIER SC570 .
    Fuser oil end On the rear of the copier is a cover that is near the lower center of rear cover you need to add silicone oil (fuser oil) to the copier and cycle power. Oil P/N A2579550
    -Carl, please let me know if this helps.
    Jun 18, 2009 | Gestetner Office Equipment & Supplies
    Gear oil
    get under truck go to the back of the rear-end housing shoul be a plug u can take out and u can kinda see in you can add the gear oil in that same hole you can only add oil up to the bottom of hole then put plug back and go on to next project
    Apr 19, 2009 | 1999 GMC Suburban
    Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
    43 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
