Question about Husqvarna 323R
Husqvarna 323r My 323R is about 3 years old. I got it out this season to use for the first time, and it crankls but cuts off after a few seconds to a minute, I can re-prime and re-start, but it cuts off each time. Suggestions?
  • Husqvarna Master
  • 1,807 Answers
Kit doesn't like being sat unused, especilly if its sat with fuel in it. Make sure you drain all the old fuel as this will no doubt have gone stale. Use fresh fuel, remove and clean the plug. You may have to clean the carb out and possibly replace internal carb gaskets if they have perished.
Posted on May 07, 2013
Husqvarna
1. [Broken Throttle cable?] I would start by making sure that when you press trigger you see the throttle cable moving linkage on carb.
2. [Spark arrester clogged?] There is a small metal screen at muffler that is known for getting clogged with carbon deposits and will prevent air/exhaust from leaving engine properly, causing it to bogg down. Try removing it and test run, if that fixes it clean or replace spark arrester.
3. [Incorrect spark plug?] If spark plug was changed recently and is not the correct one for this model trimmer it can do that. Or, if spark plug is fouled(too much carbon built up/or incorrect gap).
4. [Bad carburetor?] if there has been water in fuel, or carb has stiff diaphram inside it will not run properly.
5. [Needs service?] if none of the above work you may have to take it in for repair.
Aug 18, 2014 | Husqvarna 323R 24.5cc 2 Stroke Gas Powered...
Husqvarna 235r brush cutter starts fine when cold but won't start when hot
If it has spark and fuel then it may be worn, causing low compression and too weak to start. .
Jun 15, 2014 | Husqvarna 323R 24.5cc Straight Shaft Bike...
What is the expected lifetime of a tent?
The average lifetime of a tent is 7-10 years when using it 2-3 times a year, each time between 3-7 days. Taking good care of the tent is a major factor in its lifetime.
Jul 10, 2012 | Camping, Backpacking & Hiking
Battery will not take charge, but can jump start and it runs, but does not keep charge
Possible charging coil under the flywheel issue, or with the retifier, there is a tool called a negative shunt, this will quickly tell you if there is any charge to the battary from the engine
May 06, 2012 | Husqvarna 22HP VTwin Hydrostatic 42" Cut...
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Gas trimmer runs for a few seconds and then stops
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Husqvarna 323R Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
