Question about GE Monogram ZEU30RSFSS Stainless Steel Electric Cooktop
We replaced the glass on our Monogram ZEU30 R and its saying wait on the read out
Replaced glass and read out says wait.
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
How to change wb30t10062
remove the cook top from the counter and the remove the glass top, several screws around the edge of box. the lift top and you have access to the elements.
Jan 05, 2012 | GE Monogram ZEU30R Electric Cooktop
I have a GE Monogram cooktop and the auto ignition on once of the burners wont stop sparking. What do I need to do?
Hi go4thnx,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 25, 2011 | Cooktops
Need to clean contacts on control knobs under glass cooktop on ge jgp640 downdraft top. Ignitors wont stop clicking. Is the top glued to the chassis
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 16, 2010 | GE Monogram ZEU36 Electric Cooktop
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally...
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
Sep 27, 2017 | GE 30 in. Profile JGP989 Gas Cooktop
My glass top has a broken in the corner on my jgp932 cooktop range can i just get the glass top replaced and can i do it myself
I'm sorry to hear this. you can get just the top, but your lookingat somewhere between 300-700 dollars just for the glass. also this is not a common part and will probably be back ordered, so you'll be looking at a wait of 2-5weeks for the part. you can change it yourself but due to the cost of the glass I would have a service company change it so that if it breaks while changing they will have to pay for a second one and you wouldn't be stuck having 2 broken glasses
Apr 23, 2010 | GE 30 in. Profile JGP932 Gas Cooktop
Ge monogram cooktop model#zeu30rsf1ss error code f1 74
Hi There
I have found the codes that you need and hope this helps you.
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.Thank You for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | GE Monogram ZEU30R Electric Cooktop
Hello: One of the five knobs on the top of our GE monogram stainless-steel gas cooktop Model # zgu385 broke, and needs to be replaced. Can you help? Thanks, Daryl D.
DARYL - GO ONLINE TO REPAIRCLINIC.COM AND YOU CAN FIND THE KNOB YOU NEED, THEY MAY SELL THEM SEPPERATLY I'M NOT SURE BUT THERE PRICES ARE THE BEST I'VE SEEN IN A WHILE
Aug 24, 2009 | GE Profile JGP636 Gas Cooktop
GE Monogram ZEU30RSFSS Stainless Steel Electric Cooktop Logo
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
