Question about LG W2230S 22 inch LCD Monitor
1920x1080 resolution setting - LG W2230S 22 inch LCD Monitor
Samsung SyncMaster S24B300 is not in optimum mode of 1920x1080 60Hz as it should, but in 1360x768 ocasionally is starting up in 1920x1080 but most of the time in lower resolution mode, could FixYa he
Using our onchip Intel graphics we experienced the same problem, where the aspect ratio was displayed wrong using the native resolution of 1920x1080 at 60Hz while black bars show on the left and right side.
The problem was partly solved by using custom timing settings as you can find below:
Front Porch: 90 and 19
Back Porch: 148 and 22
Sync Width: 42 and 4
Active: 1920 and 1080
Scan rate: (auto 67.5) and 60
Then you just have to move the image down a couple of pixels using the buttons on the display.
Aug 27, 2012 | Computers & Internet
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computers & Internet
Says change resolution to 1920x1080
To change the resolution of your monitor, right click your desktop and click Properties. Go to the Settings tab, and then drag the slider in the Screen Resolution box all the way to the right. That should make it 1920x1080. Click OK and then your resolution should change.
Apr 28, 2011 | ViewSonic Computers & Internet
My ps3 wont show up on my tv screen it is a 42 inch plasma it will not show up it keeps saying invailed format what do i do?
Your 22 monitor is set up (most likely) with a max resolution on 1650x1050 and you ps3 stays set to that even when you use it on your dads 1080p TV (1920x1080) and since your 22 in monitor is a non-standard resolution (in the TV world that is ) ie 720p = 1280x720 and 1080p = 1920x1080 it has to adjust to the closest resolution (your ps3) but sometimes the auto switching of resolutions doesn't work like it should..it just doesn't work sometimes. I suggest that when you take it to your dads you adjust the resolution to 720p ahead of time (a resolution both the 22 monitor and tv should be able to handle ) and when you get to his house it should work at least enough to see everything and then when already there you can adjust up to the higher 1080p (1920x1080). Then adjust back to 720p before you go home again. Sorry for the long winded post.
Here is a link to resolutions explained in case it helps.
http://en.wikipedia.org/wiki/File:Vector_Video_Standards2.svg
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
I continully receive a message of the screen is not in optimal mode of 1920X1080. I have gone to the screen setttings and have applied this yet I continue to receive the message when I go to play a game....
Your game does not natively run at the same resolution as Windows. Check the video/graphics settings in the game itself to adjust the resolution to 1920x1080.
Note that increasing the resolution to this, will drastically increase the load on your graphic card.
Feb 26, 2011 | Samsung SyncMaster 2233SW Monitor
Using an external monitor with 1920x1080 resolution in my laptop
Well IF the Drivers support it then YES you can. Simply, make sure that the setup, is dual monitor, with extended desktop, active. Now, go into properties, and click, on the external screen, IF you can set this resolution, to what you wish, you will be able to do so. Both Monitors Do NOT have to be the same, usually, a laptop['s screen, resolution, isn't that large, but certain, screens and drivers, can support this. Ensure you have the most up-to-date Video drivers, for your Card.
Apr 04, 2010 | Dell Inspiron 1150 Notebook
I just bought a Viore LC37vf55 that has resolution of 1920x1080, but the tv shows a resolution of 720x480 how do I change the resolutin to the 1920x1080?
Resolution of your TV determent by source of the signal. FullHD (1920X1080) is available only from BD player, Upconverting DVD player or HD Media player. Here is no broadcast in 1080P (1920X1080)
Nov 02, 2009 | Televison & Video
1920x1080 Resolution Problem
less resolution that is way to high for this screen size
Jun 16, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Connecting lenovo t61 with samsung ln40a650
The LN40A650 supports 1920x1080 resolution from VGA. I know this because I've done it. It will also support lower resolutions, but certainly not higher. Drop your resolution to something low like 640x480, plug into the LN40A650, then up the resolution to 1920x1080. If this doesn't work it's 1 of 2 problems. It could be the refresh rate. Go to your display settings, click on Advanced, choose the Monitor tab, and set the screen refresh rate to 60Hz. If this still doesn't work it means your video card won't support that high of a resolution.
Sep 12, 2008 | Televison & Video
LG W2230S 22 inch LCD Monitor Logo
12 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
