Relace drum I have release developer lever and took out drum screw but I can not drum to slide out
  • 1,326 Answers
It all depends on the MAKE and MODEL of copier.... Good Luck
Posted on May 08, 2013
I am a tech and have to replace the drum on a copystar CS 1635. The service manual has been lost so I need the instructions.
open front cover, remove toner cartridge and waste toner tank. unscrew the screw below the developing unit and release the dev unit by pulling the lever. open left cover. from the front remove the screw on your left holding the drum unit. gently pull out the drum unit and replace the new unit using. the reverse procedure to be used.
Apr 20, 2011 | Kyocera Copystar CS-1635 Copier
Need steps in removing old toner from canon image runner 330S copier
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
Jan 04, 2011 | Canon ImageRUNNER 330s Copier
My copier needs developer. i would like to know how to install developer and the code to calibrate the developer
On the AR-407:
To remove the developer/toner cartridge, there is a green lever inside the front door/cover. Pull it down like you are going to refill the toner, pull it out, and there is a release lever on the right side bottom, between the cartridge and the copier. This will release the cartridge and allow you to slide the whole mechanism out.
There are 4 screws that hold the toner box onto the developer. (NOT THE TOP MOST COVER SCREWS) 2 on the left side (with the toner hopper on your right), and 1 screw on the right top, and 1 screw on the right side by the handle you use to pull the cartridge out of the machine. Make sure you also disconnect the electrical connector that attaches to the hopper motor.
Be careful not to spill the toner or developer as you are seperating the two.
The developer unit is the bottom unit.
Dump out old developer (make sure you get all of it by turning the gear on the back side). If you don't have a toner/developer vacuum, then just get as much out as you can. A normal vacuum motor will eat itself in a very short time trying to vacuum up toner or developer, because the particles are too small for a regular filter.
When you get all the developer out, then carefully open the new developer packet, and evenly pour it in. Put it back together the same way you took it apart.
Reset Developer counter : Simulation 24-5
Hope this helps!!
Ryan K
Nov 02, 2010 | Sharp AR-407 Copier
How do you remove the drum unit on a bizhub C203
This machine has more than one drum unit, its a color machine. You have three color and one black as well as 4 developer units. You need to know which one needs to be removed. Shut the machine down unplug it from the wall. The upper units are the drums, which should easily slide out. If I remember correctly you have to flip up a clip on the front of each drum unit first to slide the drum out.
Apr 08, 2010 | Konica Minolta Bizhub c203 Copier
Prep to ship Savin 4035 without damage
The main thing you need to do, is to remove the toner bottle assembly, drum unit and developer unit. There is a small black stopper you'll see once you pull out the toner bottle unit. Remove the stopper and the tray holding the bottle will slide out of the machine. The drum unit has a thumb latch on top of the unit and all you have to do is open the right side door, release the lever and remove the drum unit. DO NOT TOUCH THE DRUM! The developer unit is below the drum unit. There is one screw holding a silver piece of metal which secures the unit in place. Loose the screw and fold it down to the left and then remove the developer unit. These steps will keep toner and developer from spilling out into the machine. Good luck.
Jun 25, 2009 | Office Equipment & Supplies
HOW TO INSTALL THE DRUM UNIT for ir2230 copier
Open front cover of copier. Rotate lever (I think it's blue) to lower transfer/transport assembly. Rotate Developer/Toner assembly handle to move assembly away from drum unit. There is either a phillips screw or a plastic gripped screw that needs to be removed. Then, carefully, pull the drum unit 2/3 of the way out. At this point, the back half of the unit needs to be supported while pulling the rest of the way out. Open new drum unit. Remove all packing materials with red tag attatched...especially black paper covering new drum surface. The new Drum Unit has guides on top that line up with guides in the machine....carefully insert unit in copier until it seats FULLY. Reinstall screw to front of unit. Rotate Developer/Toner Assembly lever to cam back against Drum Unit. Rotate Transfer/Transport Assembly lever to lift assembly upward and latch. Close front cover.
Jun 13, 2009 | Canon IMAGERUNNER 2230 Copier
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
Drum on model 1510 Kyocera copier
1-6-4 Image formation section
(1) Detaching and refitting the image formation unit
Follow the procedure below to replace or check the image formation unit.
Prucedure
1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit.
2. Remove the waste toner tank and toner container.
3. Remove the two screws holding the waste toner tank cover and then the cover.
4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation
unit.
Developing retainer
Image formation unit
Connector
Oct 28, 2008 | Kyocera KM-1510 Copier
How do I change the transfer belt unit in a magicolor 7300
moz-screenshot.jpgmoz-screenshot-1.jpg1- power off the printer and make sure the indicator is not red.
2- Remove the drums and waste box
3- Remove the front door by sliding it left after releasing the two stoppers (turning them 90°) and sliding the left hinge to the left (after loosening a screw).
4- Release the green Synchronozing Roller lock levers (2).
Release the black Secondary Image Transfer lock levers (2).
Release the green Secondary Image Transfer lock lever (2).
5- release the sensor assy by turning it 90° and loosen two screws to release the belt.
6- You can now pull the belt out of the printer and replace it with a new one following the reverse procedure.
Oct 09, 2008 | Konica Minolta Office Equipment & Supplies
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Andy
Feb 28, 2008 | Sharp SF 2020 Copier
jasbo
jasbo
