Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Power trips out when jets are switched on
Recently my hot tub tripped out when I switched the jets on . Resetting the RCD only brings on the LCD and allows motor to work on low speed -as as the jets are switched on the power trips out - any suggestions greatly received Doug
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
Posted on May 09, 2013
  • Aqua Flo Master
  • 1,631 Answers
I I am presuming that low-speed is already on, and then when you push the button for high-speed Jets, as you call them, then the breaker trips?
Some control systems, utilize turning on The air blower at the same time as Jets high-speed come on. If this is the case, you could have a bad or shorted out air blower? Unplug the air blower and, see if that stops the breaker from tripping.
if breaker still trips, then the problem lies with that two speed pump motor.
you can also unplug from the power source, any ozone unit installed.
Posted on Mar 14, 2015
  • Mike Tellegen Mar 14, 2015
    Another thought, is that high-speed Jets, me turn on a second high speed pump? Is this a one pump or two o pump system?
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: i have an aqua flow
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Posted on Aug 02, 2011
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
Why is it tripping?! what can i try next? thanks
Is their not two elements, one at the top too? If it is tripping on the high limit switch it could be the thermostat Try checking the grounding of the unit.
. http://en.wikipedia.org/wiki/Residual-current_device
Jan 14, 2015 | Water Water Heaters
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Switching jets on trips RCD
This is usually an indicator that the high speed on your pump is bad.
Rod
US Parts Center
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Have drained and cleaned out a hpl103/105 hot tub left it for 1 week while on hols refilled and switched on starts pumping water through jets for about 30seconds to a minute then trips main house RCD ??...
Try disabling the heater and recheck. Unplug each component to control pack to identify which is causing gfci trip. This will isolate problem units or controls.
Mar 31, 2009 | Pool & Spa
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
291 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
