Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Dream maker spa will not heat up
Power to tub but will not heat up. This is a new tub but was purchased in 2010 but in storage for past two years.
    Top Expert:
  • Dream Maker ... Master
  • 5,045 Answers
Bad heating element or temp sensor or recirculation pump
Posted on Sep 20, 2017
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12104 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
  • 366 Answers
SOURCE: spa won't heat
you need to have the heater tested, there should be about 10 ohms of resistance when testing across the heater leads. MAKE SURE POWER IS OFF, and disconnect the wires at the posts then test for resistance.
If the multimeter reads an open, the heater is bad. Also make sure that you actually get 240 volts across the heater leads when the system is on.
You should have a spa technician test it if you are not comfortable working with electronics.
Posted on Apr 08, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Easy spa round - dream maker - overheat sensor is
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
Posted on Jun 18, 2010
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power is on but jets arnt going and pumps not pumping
I was looking for an answer to your question. I have the same problem with my Dream Maker X-400 and it is less than 2 months old. The power is on but the tub is not heating now, its down to like 82 degrees and the pump is not working but it has power. It just stopped yesterday.
Dec 18, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Over heating
Try turning the power off and back on again.
If this doesn't solve the problem you have further issues.
Regards,
Ian.
Feb 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub will not heat up. The motor is running
sounds like the heating element has gone to the next life,.....you can test it with an ohm tester,....MAKE SURE POWER OFF WHILE WORKING ON IT!!!! but no doubt it just needs a "heating element" cracklin joe
Jan 05, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Our hot tub says that there is a sensor problem detected what do we do it will not heat up or anything
either have the temperature/high limit sensors tested or replaced. Also, try resetting the tub by cutting power to it for 5 minutes if you haven't already done so.
Nov 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
26 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
