I downloaded it but t says that16 bit yourwindows dose not alow full scrien mode
  • 2,878 Answers
Increase it to 32Bit colors on display properties. Right click desktop to open options.
Posted on May 06, 2013
My Advent quantum q200 laptop will not alow me to go onto the recovery menu and also it will not alow me to see other ways to boot it up' what can I do to get to boot up with out using a reboot di
you can reach recovery mode by first shutting off your computer. 2 turn it back on and as soon as you press the power key start tapping f5 constantly and your screen should go into safe mode. you can the put your computer to recover or set it back to an earlier date and time. hope this helps.
Apr 29, 2012 | Computers & Internet
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
How do i install a software for windows xp on my windows 7
Most of the softwares for Microsoft Windows XP are compatible with latest Operating Systems (OS) of the same company. So you can try to install the software through the installer.
If the installation fails with error you should understand what is the reason.
If the reason is incompetibility with the OS you may consider to install Windows XP Mode on your Windows 7. You can download Windows XP Mode from the Microsoft site. This is the link to the page. You should choose the options from the drop-down menus according your system (32 bit or 64 bit).
Then you will have the oportunity to download Windows XP Mode and Virtual PC.
After installing these softwares and restarting the computer, you could enter Windows XP mode and install your XP based software. I hope this helps you. Good luck!
Sep 28, 2011 | Microsoft Windows 7 Ultimate, Full Version...
How to get full screen
TRY this first go to device manager and disable the display hardware and restart the pc dose it come full screen then its releted to the display driver you have to download the latest display driver from the hp sight and reinstall it if you still get the screen small try to set the resolution to 1024X768 and 32 bit
and check if it ok or else you have to go to the bios by pressing the del key or f12 depends on the model and make and go to advance hardware setting and on board hardware setting and check the display device and check the setting for the display make it full screen display.
and you hsould be going on ok.
thanks
Dec 12, 2010 | HP Compaq Presario R4000 Notebook
I requre 845 sound driver
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and make sureyou select the Windows XP or Vista version of the drivers that matches yourWindows operating system. Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Dec 04, 2010 | Intel 845GE Motherboard
My cannon canoscan lide 20 lide 30 driver,dose not install with windows 7
Do you have the 32-bit OS or the 64-bit OS? The Canon drivers will work in 32-bit Win7. However, Canon doesn't support these scanners in the 64-bit OS. The only way to make the scanner work in the 64-bit OS is to run either a dual boot system or a virtual computer with a supported OS. The Vista x64 bit driver doesn't work even if you use the compatibility mode.
If you have Win7 Ultimate, you can download Microsoft's Virtual PC and the XP mode for free. All other virtualization software options (Virtual PC, Parallels, VMWare) require a paid (licensed) version of the OS. Then install the scanner in the virtual computer and transfer files to external media to share it with the main computer. Dual boot systems have the same restriction of needing a valid OS.
I'm not aware of any Canon drivers for this scanner under UNIX.
I wish that I could be of more help.
Sep 02, 2010 | Computers & Internet
When diablo 2 is loaded the game dose not go full
If you are not playing in windowed mode, Diablo II takes control of your screen and changes it's resolution down to 800x600 or 640x480. If you are in windowed mode, there are other things on the screen, so Diablo does not have control of your resolution. Diablo II can not scale up it's window to more than 800x600. If you want the 800x600 to take up more of your screen, then set your screen to a smaller resolution.
Apr 29, 2010 | HP Pavilion dv6000z Notebook
Software dose not work with Visa Windows, why
DesignJet 100 will work with Vista ! I worked it out !
You need a windows network for the job. Everyone must be in 64 bit mode.
Apr 10, 2008 | Office Equipment & Supplies
Phone
try to remove
C200 and R200
Dec 20, 2007 | Nokia 1112 Cellular Phone
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
