Question about LG LSC26905TT Side by Side Refrigerator
Door Handles Loose
I know this is minor...But How do I tighten the handles? I was afraid to try to pry off the covers...
Pry off the covers carefully and tighten the screws. The covers will come off. You can even place a thin piece of cardboard between the screw drive and the refrigerators surface so you wont scratch it. Hope this helps
Posted on Aug 09, 2007
Thanks....I solved the problem with your help
Posted on Sep 03, 2007
SOURCE:
2007 Yukon Denali GMC inside door handle on driverside is loose and want on the door
Unfortunately, they seem to be making door handles cheaper now and many people are having problems with them. If it is loose, the only thing you can do is unscrew and pry off the inner door panel and once inside the door, tighten up the connections. Try looking at this informative YouTube.com video: https://www.youtube.com/watch?v=pesX5dZeGwo
I hope that helps! :)
Apr 05, 2015 | 2007 GMC Yukon Denali
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Mar 25, 2014 | Hardware & Accessories
The door handles are loose. I can't tell how to get to the inside of the doors. Do the handle covers just pop off? How do I tighten the handles?
I believe the fixings for the handles are under the door seals. If you just peel back the seal you should find the fixings.
Mar 07, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Whirlpool gold side by side door handle is loose.I can't find the way to tighten. IT appears the screws are underneath the rubber gasket, but I am a little wary of tearing it loose without anew gasket.
Most door handles now are front repairable. I can't tell without the model number which style you have, but most units have an insert in the door handle. You have to pry this insert out, to get to the screws for the handle. Some handles actually clip on to the door by sliding the handle up or down to clip it on or off. Good Luck, Appliance Specialists.
Feb 04, 2010 | Refrigerators
How do I tighten the door handles on a ge refrig? how do I get to the screw?
PROBLEM SOLVED.
GENTLY PRY OPEN THE TOP COVER OF THE HANDLE WITH A VERY SMALL SCREW DIVER, AND TIGHTEN A SMALL SCREW.
Oct 21, 2009 | GE Refrigerators
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
126 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
