Fisher & paykel washer model# wa37t26. Had
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
Fisher & paykel washer no power going to it
No reset button. There is a fuse it is soldered on & part of the main control board. They don't blow the fuse for no reason, so you need to be able to test & check everything to find out why the fuse blew (if it has) If you just replace the control board without checking then there is a good chance it may blow the new board as well. There will be no warranty on the board in that case. You really need to call a repair company who will test everything first.
Dec 27, 2015 | Fisher and Paykel Washing Machines
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Washer not draining
try checking the filter or drain hose you may also check the pump it sounds like the is a blockage somewhere
Dec 02, 2011 | Fisher and Paykel WA37T26 Top Load...
I have a Fisher & Paykel 6.5 Excellence, my garage door had a mishap and the wiring blew and is now all melted, have found that my washing machine now does not go whch is more than likely due to the...
i am sorry to say there is no reset switch if u are geting power to the unit and the display is not coming on then u have a bad control board located in the front panel.
Apr 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
My Model GW712 won't spin or drain Top loader fisher & paykel
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher paykel washer stopped in the middle of a wash leaving the clothes soaking wet and now the power button does not work
Either the computer board is dead OR the pump was on it's way out & took the board with it.If your lucky the pump is just dead & therefore not providing power up to the board,thats the cheaper way to go first.Or you may be up for both.It was probably pumping out at the time when it stopped.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
No power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Jul 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
