Question about Fedders A6P09S2A Air Conditioner
Drain pan fills quickly
I have a Fedders portable AC model A6PO952BCOM. The water from the drain pan needs to be released every hour.I used the AC all last summer and only had to drain it 3 times all summer. Any suggestions to fix this problem would be appreciated. Thank You
  • bornmfg Jul 20, 2008
    Water drains and fills up every hour
  • faatimam Jul 25, 2008
    The first summer I had the ac, I only had to drain it once at the end of summer when I was putting it away. Last summer and this summer I am having to drain the water every hour or so. Also, the coils are icing up.
On the bottom coil there is a small motor with a blade that goes between the coils to sling water//have a fedders unit with the same problem and the little motor was bad
Posted on Aug 28, 2008
  • 50 Answers
Can you descibe where the unit is located and what climate you are in? Thanks
Posted on Aug 10, 2007
SOURCE:
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
My portable ac unit keeps filling with water and shutting off. Why is it shutting down once an hour and flashing p2?
if it's a window unit it needs to sit at an angle so the water can drain out of the back. Make sure the drain is unclogged
Jul 16, 2012 | Heating & Cooling
Why is my lg portable ac leaking water from bottom of unit
There should be a drain pipe at the side or bottom of unit to run a drain line. Locate drain and clean it out .
Feb 26, 2018 | LG Heating & Cooling
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
I would like a manual for this portable airconditioner. I need to llnow if I neede to drain the water from this unit?
Since you didn't mention who the manufacturer is and the model number, it makes it a little difficult. But, most all portable AC units drain the same way. There's a drain plug on the back of the unit, just above floor level. It may have a door cover over it, so you will have to remove it first, to access the drain plug.
There are 2 ways to drain the unit. Use a shallow sided pan, capable of holding 1 quart of water or roll the unit to a floor drain or outside, before removing the drain plug. The Drain Plug screws out. If you drain theunit into a pan, turn the unit OFF & Unplug it first.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | Heating & Cooling
Fedders AC leaking water from front, older model was in storage. Cant find the manual to make sure it's installed proper, or see if we need to clean somehting out. It leaks when it's running, then...
The unit needs to be tilted down 1/4/" to 1/2" on the outside of the window. Also check the drain pan's drain hole, under the unit (outside the window) for clogs. Doing all of this should solve the problem.
Jul 11, 2011 | Fedders AEQ07FBG Air Conditioner
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
MODEL CPRD12HX7-Q THE UNIT WILL NOT TURN ON AND...
I have the same model and if you have been running the dehumidifier the internal water tank will fill with condensate water. You will need to unplug the black plug (in back of unit) to release the pints of water it has accumulated in the tank. Be sure to have a pan under the plug as it will drain immediately. Do not tip the portable unit if you need to put in a shower stall to drain, as water will leak out of the internal water tank into your unit. Hope this helps.
May 21, 2010 | Haier CPRD12XH7 Air Conditioner
Fedders A6P09S2A Air Conditioner Logo
365 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
