Question about Dell OptiPlex 380 PC Desktop
Alert System battery voltage is low
After i replace new 3v battery on main-board, the message still appear when boot up the system. any help? espr_it@yahoo.com
  • Dell Master
  • 7,627 Answers
If it's installers correctly , reseat it and verify. Try unplugging the machine for a few minutes. Did you try to reset the Time in BIOS?
Posted on May 04, 2013
5 Suggested Answers
shoib127300
  • 55 Answers
SOURCE: my dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Posted on Mar 17, 2009
Staric
  • 10 Answers
SOURCE: Alert! system battery voltage is
Dell claims the problem is caused by some surge suppressors - and that you can eliminate it by removing the surge suppressor and plugging the PC directly into the wall outlet. Call Tech Support and have them send you a battery, or look in the system docuemtation and go to Radio Shack and get a new one if you are in a hurry.
Posted on Jun 21, 2011
DickCanFixIt
  • 948 Answers
SOURCE: I have a dell GX 270 that has orange light on
The battery message means you need to change the battery on the motherboard, it looks like a coin about the size of a nickel. Which fan is malfunctioning, the power supply fan, the case fan, or the processor fan?
Posted on May 19, 2009
SOURCE: Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Posted on Jul 11, 2008
How do I replace the battery in a first alert FA120C system? The system beeps every 40 seconds.
Hi Nzingha. Check your mail panel, it should show which zone has got a battery problem, if no zone is shown, it is the main backup battery that is low, this should charge all the time while mains is available so it will only happen if the standby battery has a problem.
When you have determined which sensor has a low battery, use a flat screw driver, look for the small slit/indent and lift the front side from the rear to open. You should be able to see the batteries then, replace with the same making sure about the polarity when reinserting the new ones. Some sensors also have a pushbutton that you have to press when all batteries are out to reset the sensor. Hope this helps, see attached manual. http://www.securtek.com/products-services/system-user-guides/ademco/ADEMCO%20FA120C%20User&%2339;s%20Manual.pdf
Nov 15, 2014 | First Alert Alarm System
Alert system battery voltage is low dell optiplex 745
This error indicates the cmos battery needs replaced on the main board.
This battery is small, silver, and about the size of a nickle.
They can be purchased cheaply and are usually 3.3volts
Sep 26, 2014 | Computers & Internet
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
Have a Dell XPS 600 problem. I am getting a message when I turn on the computer, "Keyboard Failure Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run setup utility." What should...
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Oct 14, 2010 | Dell XPS 600 PC Desktop
Acer Laptop ,Battery flat,Charging Light only comes on Briefly then nothing, If i take battery out Laptop boots up,but only if I take battery off..thanks
yeap....itz the main/mother board..
do it only if u r a professional..
disconnect ur system from power mains..open the cabinet..
replace the cmos battery (+3v; type: 2032 probably) on the main/mother board..connect to the power n boot, enter into cmos setup utility (by briskly pressing DEL/F1/F2/F10 as applicable)..set the time here..save n exit n restart..see if itz rectified..
if not probably the board is damaged, if u r a professional check the capacitors(above 1000mfd) n mosfets, check for the circuitry around south-bridge..
contact ur system admin/vendor....
Nov 01, 2009 | Acer Computers & Internet
Hard drive has been wiped trying to re boot from windows xp cd. changed battery on mother board. getting alert low battery voltage and pc will not re boot. asking re boot trying pressing F1
It sounds like you either got a bad battery or one that is not compatible with your motherboard. Try replacing with a new battery that is compatible with your mb & see if this corrects the error. If you just bought the other battery you are using you should be able to get a refund or store credit towards the new one. Also make sure all the cables are properly seated as one may have come lose during original replacement. Hope this helps.
Jul 02, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
Dell Dimension 8300
Nov 01, 2007 | Dell Dimension 4600 PC Desktop
Dell OptiPlex 380 PC Desktop Logo
466 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
