Question about Hotpoint Dryers
Changed belt on dryer model number TCM 585 but now ned wiring diagram for it as got in a tangle with them, can you help with this
TheMobilian
  • 8220 Answers
SOURCE: whirlpool dryer belt routing diagram for dryer
Here you go
Posted on Aug 12, 2010
SyxPak
SOURCE: wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Posted on Apr 01, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
Jahn27
  • 1554 Answers
SOURCE: how to change the belt in the kenmore dryer model
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
Posted on May 29, 2010
  • 3 Answers
SOURCE: I have a samsung electric
The Samsung Dryer tension pulley assembly is counter-intuitive (especially when your arms are stuck in the small sharp-edged hole). The image shows the proper setup and belt path..._206.jpg
Posted on Dec 01, 2010
Belt replaced around drum, too loose! Parts store insists it is the correct size for GE dryer. Model # DBXR453GT3WW (1996) Can't figure out what is wrong?
The part# i have for that model number for the belt is WE12M29 the previous part number for that was WE12M22 is either of those the part number for the belt ?? if yes it should be the correct one
one more thing that may help ya is view the diagram here of how it fits onto the idler pulley/motor pulley http://www.repairclinic.com/Dryer-Belt-Diagrams for your dryer it will be DIAGRAM L
GENE
Aug 29, 2011 | GE Dryers
Threading the dryer belt on my stackable frigidaire model. i need a diagram please.pulleys,tensioner and drum it is not getting tight. just need a pic.
A model number would have helped me help you a lot quicker. It took a lot of time just to try and guess here.
Yours will be one of these 2 diagrams:
westing.gif for 1995 and newer models ^--NOTE Belt ribs away from the drum on this one: frank.gif 1985-1995 models ^-Note: Belt ribs face drum on this one Thanks for choosing FixYa, Kelly
Aug 17, 2011 | Dryers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
I need a routing diagram for a serpentine belt on a 1993 4.9 northstar engine
Heres your belt diagram for the 1993 engine 4.9, i hope this is helpful, good luck.johnjohn2_41.gif
Dec 24, 2010 | Cadillac Seville Cars & Trucks
Installing belt around drum
There are several helpful dryer belt diagrams that are available at repairclinic.com. Just go to the site and click on "Get Repair Help". Under Large Appliances, select "Dryers". Look for the "Click Here for a Belt Installation Diagram" link. Refer to either diagrams H or K. If you are confused on which diagram applies to your dryer, please post back with your MODEL NUMBER so I can assist you further. I hope this helps you.
Dec 18, 2010 | Whirlpool Dryers
We need to know where the tension pulley goes and we need a diagram to show us how it goes in
You can view an extensive list of dryer belt diagrams at the following website:
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help
The diagrams are listed by manufacturer and model. If you still need assistance in determing which diagram to use, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If the link does not work for you, go to repairclinic.com and click on the "Get Repair Help" link at the top of the page. Select "Dryer", followed by the "Click here for belt installation diagram" link.
Nov 23, 2010 | Dryers
Where do i find belt routing diagrams?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. Depending on the model Kenmore you have, you will refer to either diagram H, B, or K. If you have trouble being able to determine which diagram you should use, please post back with your complete MODEL NUMBER so I can assist you further. I hope you find this information helpful.
Apr 21, 2010 | Kenmore 62602 Electric Dryer
I cant find my dryer model number online.
Go to appliancepartspros.com and type in your model number. Use the suggested model number they provide, which is the XMW0 suffix you have listed. The part numbers will be the same for these models. If you look under the "Cabinet" diagram at item number 56, it states in the part description that this belt replaces the 5 rib (wider) belt that you have and fits all Whirlpool models. The part number is AP2946843.
For a diagram on how to replace the belt, go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, is a link for "Dryer Belt Diagrams" under the "Special Features" section. Scroll down to Whirlpool and use diagram H. I hope this helps you. Let me know if you require additional assistance.
Jan 03, 2009 | Dryers
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Dryers Logo
82 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
