Trane xv90 After a power outage, my Trane XV90 says on the thermostat, "Aux heat." It won't go on. Is there a reset button?
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Trane Heat Pump
What caused the power outage? Check the outdoor disconnect to the condenser unit. The fuses may have blown, causing the heat pump to not function and depending on the aux. heat to carry the load.
Posted on Dec 18, 2007
Control Board P/N 50A55-571 / Trane P/N D341122P01 red indicator light flashes at 2-3 sec. intervals.
No power where? If you have no power how can u determine the board is bad? Need to start where power enters the machine. Then to transformer, then to board. Trane units usually have a bus fuse rather than a blade fuse.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 11, 2018 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane xr12 heat pump switching to aux
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Trane Heater A/C Airflow Control
i had a similar problem, and a six inch duct and inline booster fan didnt help, the room was just to far away from the furnace and ac. to save energy, i use an oil rad in the winter, and a portable ac in the summer, it works great.my house is a back split, so its a common problem. in the summer, all downstairs dampers should be closed to push the cold air upstairs ,as it will come back down anyway and the basement is cooler as it is. so if you have 4 flores, you close the bottom 2. bungalow you close the basement
Jul 22, 2009 | Heating & Cooling
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
Humidity too low
I corrected the problem...RH is rising nicely!! Installed by "professionals" on my Trane XV90....I redid their wiring and now have the following setup...
600A water supply coming from hot water line.
Removed orifice inside incoming feed tube.
control incoming water flow from saddlevalve on hot water supply ( make sure its a nice solid flow, no drips, but no "force" too it either)..enough to insure entire evaporator unit is wet and water is slightly flowing out of bottom to drain.
I also have it wired to run when ever the furnace blower is on. Heat or no heat. XV90 is variable speed, and by doing this the 600a is always adding moisture, until it reaches correct RH%
Also, I disconnected the outdoor temp sensor. I went to Radio Shack and bought a 47K ohm resistor ( 1/2 watt....4 pack for 99 cents). Installed that in place of outdoor sensor...now runs in manual mode. Have unit currently set to number 5.
Jan 14, 2009 | Aprilaire 600 Humidifier
Trane Heat Pump
Dec 16, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
