Question about Nespresso Gran Maestria Platinum
Nespresso machine yellow light - Nespresso Gran Maestria Platinum
How do I repair a Teflon tube on NESPRESSO Pixie COFFE MACHINE
You purchase the correct tube as a spare part from a supplier. Give your model to Nespresso and ask for direction.
Dec 20, 2014 | Frontgate Nespresso Pixie Brown Machine -...
I have a delonghi esam 4200 and the following lights are on solid, the small & large green cup lights plus the triangular light with the ! is also on solid. This error code is not in the manua
your are correct it is not. and according the the troubleshooting guide that I downloaded it shows the following:
If this persists please contact the Nespresso Club.
  1. 1-800-562-1465
  2. Call toll-free: 1-800-562-1465 for OriginalLine members. Call toll-free: 1-877-964-6299 for VertuoLine members. Visit a Nespresso Boutique. During the account registration process you may register your machine.
Customer Service for Club Members ' Nespresso USA
https://www.nespresso.com/us/en/customer-service-nespresso-club
Nov 10, 2014 | DeLonghi Magnifica ESAM4200S Espresso...
Why does My nespresso machine keeps on flashing 3 lights
Please see http://www.fixya.com/support/t14787831-nespresso_u_all_lights_flashing_pod for previous answer, or see troubleshooting at http://www.nespresso-us.com/media/product/PDF/38manual.pdf
Jul 06, 2014 | Nespresso Coffee Makers & Espresso...
Electrical issue
Remember, the machine needs to be setup as per the manual. If you do not have power to the unit; try it at another wall outlet. Other than that, call 1 866 901 2739 for technical support.
Feb 23, 2014 | Nespresso D290 Espresso Machine
I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and ruined...
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Sep 23, 2012 | Frontgate Nespresso Pixie Brown Machine -...
I have a nespresso D290 It shows that its on but a small yellow light keeps flashing and when I push other buttons it beeps
The instructions for your Nespresso LeCube 250 can be downloaded here:
http://www.nespresso.com/fileadmin/ca-en/_img/manuals/NES_08_00_EN_Nespresso.pdf
The flashing light may indicate a problem with the heating system and proper water temperature is not being reached. Have you descaled your machine?
You may wish to seek guidance from Nespresso: 1-800-562-1465
Oct 30, 2011 | Nespresso D290 Espresso Machine
I have a nespresso latissima machine,Got it for x-mas, and now there is constant yellow light on the water (the tank is full, and there is a blue light when it is time to fill it up...) What does it mean?
I just had this same problem with my brand new Latissima premium and I fixed it by adjusting the water hardness setting. The yellow water warning light being constantly on means the machine thinks the water is too hard and the machine needs descaling. In my case, the machine just needed to learn how hard my water actually is. In the manuals that came with the machine you should have been given a ph testing strip and there are instructions in the user guide about how to adjust the water hardness settings. As soon as I did that, the yellow hard warning light immediately went off. In my case the water setting needed to be adjusted to the 7-14 ph setting. I'm attaching pics of the water hardness setting instructions from the manual.dberlyne_3.jpgdberlyne_2.jpgdberlyne_1.jpgdberlyne_0.jpgdberlyne.jpg
Dec 28, 2009 | Nespresso C190 Espresso Machine
The Nespresso won't make coffee yellow light keeps blinking
This is because there is either too much water in the drip tray, the empties container is full or the drip tray is not placed correctly. This took me a while to figure out as well, and the manual was little help. Nespresso is located in Switzerland so their support number is international. Hope this helps someone...
May 25, 2009 | Nespresso D290 Espresso Machine
Where can I download the manual?
The manuals are available on the Nespresso website (www.nespresso.com). Click on the "machines" section, and then choose the le cube. Click on the details page (https://secure.nespresso.com/precom/sima/fiche__NESPRESSO_Le_Cube_D185__N_D185_1_us_en.html) and you should see the link for downloading the manual. You can also download the descaling instructions as well.
Aug 06, 2008 | Nespresso Le Cube
Nespresso Gran Maestria Platinum Logo
160 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
