Question about RCA P52926 52" Rear Projection Television
Red bulb not working RCA P85927
I have notice in the back of the red light is not on I could see the green and blue light but the red is blown out. Is there a way I can purchase the red kline bulb and install it myself.
Before we think of replacing the bulb, check the heater if it gets the power,check also for loose contact on the CRT socket.
Posted on Aug 09, 2007
SOURCE:
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
RCA 42" Projection TV
Did you cheak the bulb? I believe those also have red yellow and blue lights to make up the color spectrum you should check all of these bulbs
Feb 29, 2012 | RCA Televison & Video
I have and 65" Mitsubishy HDTV model WS-65511 serial :118393 I never had a problem before but las week i was watching a program and sudenly a second blue image was on the scrren, i decided to open the...
there just might be a slight chance an adjustment of g2 high voltage to the blue tube might help however there is a good chance there is a problem with the tube
Oct 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubitishi TV model VS50800 (1998) - sound but no picture. What could the problem be, defective 'bulb'?
There may be a switch on the back of the TV that chooses whether to output video to the component connections or the RCA/S-Video connections.
RCA cables - red, yellow, white
S-Video - single cord (usually black)
Component Video Cables - red, green, blue
Sep 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The picture is red, does this mean a bulb has burned out ?
there will be three bulbs, red blue and green. if the display is red, than one of the contrasting colors is shot, more likely the blue.
Jun 18, 2009 | RCA D52W19 52" Rear Projection Television
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turns green and shuts off
I had an electrician come over. He pulled out the bulb that was dead (for me it was the color that was flashing before it would turn off) and now I have a blue and green TV with no red. He said that the only way to fix it is to replace the red lamp with a new one.
Jan 16, 2009 | Sony KP-65WS500 65" Rear Projection...
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
When tv is on it just loses all color but blue
the tubes are going out on you,probably time to replace them
Oct 27, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture red
the tubes are weak you may want to have a shop look at it but i know the tubes are weak
Aug 06, 2008 | RCA P61927 61" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
