Question about Hardware & Accessories
Help with 12v Frontier timer
Instructions do not give wiring diagrams. Can anybody give me positive/negative connections for input and output
  • 5,245 Answers
This is Intermatic PB series timer module adapted for various applications, often low-voltage AC and DC loads. Copy following links for specific wiring diagrams:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#fm
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/How-to-wire-TB118-TB178-timer.html#fm
Timer can be wired for numerous applications.
Power is connected to terminals 1 and 2, jumper wire is connected from terminal 1 to terminal 3.
Load wires connect to either terminal 4-5, and to terminal 2.
For loads greater than amp rating, use timer to control contactor. Add line fuse to protect timer from overampping.
Posted on May 04, 2013
  • 3 more comments
  • mark schull May 04, 2013
    Thanks Gene. So from battery, positive to terminal 1, negative wire to terminal 2, jumper wire (positive) from 1 to 3. Then to light we have negative to terminal 2 and positive wire to terminal 4 or 5. Is this correct?
  • Gene Haynes May 05, 2013
    correct
  • mark schull May 05, 2013
    Think I got it Gene. No negative wire in play. Merely using timer as a interruption to positive input. Sat down and had a think about it. Thanks again.
    Here is Hot interrupt wiring:http://waterheatertimer.org/images/How-t... Your video clearly identified product, making it ez to see markings on back timer.
2 Suggested Answers
SOURCE: need instructions for installing- model
Open following link for large print instructions, and specific wiring step.
Read the additional help for step by step action.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html#wiring
The 'wire from fixture' means the wire that goes to the light.
One of the two wires that previously connected to switch is 'wire from fixture.'
The wire that goes to light will not show any power when it is disconnected from switch, and will not test positive or negative.
Single phase household electricity does not test positive or negative.
Household electricity is AC current which means the electricity is an oscillating wave that reverses direction either 50 or 60 times per second, depending on which country you reside.
For example each electrical appliance, like TV or treadmill, has small rating sticker, and in US, the rating sticker will show 60Hz. This is 60 cycles per second. A 60Hz appliance will not work in India or New Zealand or other countries that have 50Hz electricity.
Batteries are DC current and will test positive or negative.
Household electricity is AC current and does not test positive or negative.
Open following link for general illustration of household wiring:
http://waterheatertimer.org/See-inside-main-breaker-box.html
Posted on Sep 07, 2011
2013 Nissan Frontier S, radio wire diagram.
2013 Nissan Frontier Car Stereo Wiring Guide
Car Radio Battery Constant 12V+ Wire: Yellow
Car Radio Accessory Switched 12V+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red
Car Radio Dimmer Wire: Gray
Left Front Speaker Positive Wire (+): Brown
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Dec 02, 2016 | Nissan Cars & Trucks
How to wire koyo timer kt-v4s-c-d
Koyo kt-v4s-c-d is a 12-24Volt DC pin timer.
Timer mounts in a pin base, and wires are connected to numbered screw terminals on the base.
Timer has 12 pins, and is installed onto 12 pin base.
The base terminals are labeled 1 2 3 4 5 6 7 8 9 10 11 12
The 12-24V DC input voltage connects to terminals 11 and 12, and powers the timer mechanism. Positive to terminal 11, and negative to terminal 12.
The other terminals are dry, and receive no power when input is connected to 11 and 12, except the illustration seems to show the timer will electrically connect terminal 5 and negative charged terminal 12. Use multimeter to check each terminal after power is applied.
COM terminal is 8. Run jumper wire from one of the input terminals to terminal 8. When timer is OFF, then NC terminal 9 has power output. When timer is ON, then NO terminal 10 has output.
Timer functions are set using 8 dip switches.
Copy following link for some illustrations.
http://waterheatertimer.org/How-to-wire-pin-timers.html
Copy following link for timer manual.
http://www.automationdirect.com/static/manuals/koyotimerm/koyotimerm.pdf
Jul 12, 2012 | Hardware & Accessories
We have a DEH-6 pioneer radio that we are trying to install in the 1994 dodge caravan.We cannot find where to hook the white wire from the radio. when you turn the ignition on the radio lights up but the...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
May 29, 2011 | Pioneer DEH-P690UB CD Player
Need wiring diagram for pioneer deh p2900mp wiring diagram
Hope this helps.
Feb 23, 2011 | Car Audio & Video
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
Wen radio is turned up ampp goes into protection
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Oct 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need a diagram of hw to hook 2 subs to 4 channel amp
Oct 08, 2009 | Kenwood Car Audio & Video
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Who needs a «remote DC terminal» ???
Hello labdes,
The "remote" terminal of the amp requires a +12V signal to rurn the amp on. Normally, this is supplied by a specific wire from the vehicle "head unit". But you can simply jumper it to the positive 12V source. + should go to the 12V positive and to "remote", - to the 12V negative. I'd wire a switch across the "remote" and "power" terminals to have a way to turn the amp on and off.
I'm hoping that your "car amp" has speaker level inputs, because the PC card is probably not going to have preamp outputs. If the amp has only RCA type inputs, you will need to purchase a LOC (line output converter) such as the PAC SNI-35 shown here. They are also usually available at your local car audio shop and some big box stores.
Hope this helps.
Jun 13, 2009 | Lanzar MXA 412 Car Audio Amplifier
How do I bench test?
A bench test will require a 12VDC source, such as an car battery. You would connect wires according to the instuctions (i.e., red to 12v(+), black to 12v(-), and the required ignition wire you can toggle by touching it to the 12v(+) when required. Your schematics should show how the relay needs to be wired. And it's really simple. 85 and 86 are the coils. In most cases, (for example), 85 will have a 12v(+) connection, 86 will receive an input from the remote keyless entry (RKE) to activate the option. So, if you're using this relay, say, to activate your 12V(+) parklights, the 12V(-) from the RKE will go to 86, you'll have another 12V(+) wire connected to 30, and the connection to the vehicles parklights will connect to 87. 87a will have no connection in this application. The 12v(+) to the relay should come from a fused 12v(+) source.Trunk release will work the same, depending on whether it's a positive or negative trigger (depends on vehicle). You'll use the trunk output (should be a negative output from RKE) to the relay as described above. If the Trunk release is a negative trigger, you would connect a wired from a ground source (i.e., metal screw in kick panel) to 30, and 87 would go to the trunk's trigger wire at the switch.
May 26, 2009 | Vehicle Parts & Accessories
Hardware & Accessories Logo
583 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
