Question about Coleman Powermate Proforce 2500 Generator
Owners manual runs most things small but will not start my compressor
  • Coleman Master
  • 17,093 Answers
High amperage draw on motor on startup
Posted on May 19, 2013
Model MBF2255KEW Refrigerator is not cooling. What are some things we can try to see if it will reset?
First, unplug the unit for 10 minutes to reset the electronics.
Second, replug and set controls to cold settings.
Third, if compressor is working you should hear noise to confirm.
4. Check fan is running efficiently with no noise. If not, replace fan motor and recheck.
5. Check damper control unit is working (see diagram in owners manual) if you have it handy or download it online from below.
Maytag Kitchen Laundry Home Appliances
6. If compressor is running, strange noises are heard, or unit shuts down after start-up, or fails to start, either the compressor has a leak resulting in a no pressure automatic shutdown or the electronic control unit is faulty.
Unfortunately, there is no quick fix for either and a Certified Repair Technician is required to either fix or generate a Warranty Replacement Claim.
Apr 22, 2017 | Refrigerators
The compressor of my split a/c stops working but will pick again after some time
If your A/c is non-inverter type, then its normal.
another cause of stopping compressors are due to high amperes comming in to the compressor. (power surge or high ampere)
have your unit cleaned first, then check the amperes from your compressor using a clamp ameter.
another cause is the starting assist (a small box-like thing beside the starting capacitor). this prevents your compressor from running even if it has to. you can by-pass that starting assist thing.
Jan 09, 2015 | Heating & Cooling
Why would my refrigerator stop cooling?
The first thing I would check is the compressor start device. It is usually a small white square box on the side of the compressor. Remove it and shake it if it rattles then it is usually bad. Replace this and the compressor should start up. If the compressor is not getting power then it could be the thermostat or the defrost timer or control. Check if the compressor fan is running this is controlled by the thermostat and defrost timer also. if it is running then check the start device.
Jul 30, 2014 | Whirlpool Refrigerators
I need to know how to get to the motor coils to clean the dust off of them. The space is so small I can't get to them. Could you send me a Owners Manual? Or just the page of how to clean the coils.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Refrigerators
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Where can I find the owner's manual for an IR Type 30 model 25T
IR has not made their owner's manuals available online. You have to contact your nearest dealer in order to get one. If you do get one, could you please consider uploading the manual to fixya.com to help other people who a looking for the same thing.
May 13, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Coil in freezer ice on top not on bottom
soundslike a "low charge" or inefficient compressor. defimalty a "sealed system repair" needed, nothing for a homeowner, and depending on age may not be worth costof repair, check your owners manual, you should have at least a 5yr warr.
Mar 01, 2009 | Kenmore Refrigerators
Coleman Powermate Proforce 2500 Generator Logo
69 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
