Question about Dishwashers
E1 error on kenwood didhwasher
Won't run gets e1 message
    Scholar:
  • 77 Answers
Gday
As you said, it is not getting water.
E1 is just the machine telling you this.
A couple of easy ones to check:
1. remove the hose where it screws on to the dishwasher, leave the other end connected to the tap (preferably put the machine end in the sink or a bucket as to not make a mess), and turn on the tap. If the water is not getting through the hose, it may have a faulty water block (flood preventer) on it.
2. If there is water getting through the hose, make sure that the hose is not kinking as you push the dishwasher back in to its hole.
3. If there is water getting through the hose and it is not kinked, and you cannot hear any water going into the machine, you may have a faulty inlet solenoid or control board. Might be cheaper to get someone in to fix it. If you were to guess, I would start with the solenoid, as it would be the far cheaper part.
4. If you do hear water rushing in before you get the E1, then the machine does not know that it is getting water. Could be either a faulty pressure switch or the pressure tube that goes to the switch.
Hope this helps
Adam
Posted on Jun 01, 2013
  • mel booth Jun 04, 2013
    Thank u for this advice I did take off Jose check for blocks etc n still n luck so my super clever husband switched it off n on at wall n it has worked ever since!!!! Weird
  • Adzhall Jun 05, 2013
    I dare say that there was a pressure block against the inlet solenoid. When you removed the hose to check it, this pressure would have been released. Once re-connected and turned back on, it is all good. I am glad that you are back in action. There is nothing worse than washing up by hand =)
SOURCE: E6
I had this problem and fixed it tonight. When selecting a program water pumps into the machine, but with no drain i ended up with too much water and error code E6.
I traced the fault to a broken wire between the electronic module in the door and the pump. The point at which the door opens and closes on the cables had frayed the insulation and broken through the wire. As this was the live feed to the pump and a potential short from 240VAC to the chassis its dangerous!!
Repairing the wire break and re-insulating fixed the problem.
Lee
Posted on Aug 11, 2008
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
SOURCE: E1 Error Message
Yep, impeller motor problem.... mines done it twice now. Absolute piece of **** dishwasher. I HATE IT!
Posted on Dec 16, 2008
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
GodBlessU
  • 3513 Answers
SOURCE: e1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Posted on Sep 10, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Grohe Blue - Error E1
    You have to disconnect the power supply for more than 30 sec
    Nov 03, 2015 | Grohe 31251 Blue Chilled & Sparkling Dual...
    Kenwood KDW45X13 E1 error message
    Poor water supply, check the supply hose is not kinked. Check the supply tap is fully on. Check the debris filter in the hose to machine connection is clean.
    Jan 26, 2014 | Kenwood Dishwashers
    My whirlpool oven locke with F5 E1 what to do
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks
    Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
    The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
    You should disconnect power for 15 seconds and reconnect and see if that helps.
    If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
    Thank You and please rate my answer if it was helpful..
    Jun 19, 2011 | Kenmore Ovens
    Hi Kenwood dishwasher kdw60x10 - runs cycle then stops showing error E1 - still full of water.
    I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
    May 14, 2011 | Dishwashers
    E1 ALARM ON KENWOOD DISHWASHER
    An E1 is a control board error. Sometimes it can be soldered at the heat element relay which get hot often and can melt the solder ion the board. It is fairly easy to replace a control board.
    Feb 07, 2011 | Kenwood KDW243A Builtin Dishwasher
    Treadmill cuts out after 10 seconds and gives an E1 message.
    Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
    Good luck.
    Jan 23, 2010 | Horizon Exercise & Fitness
    Error E1 mean?
    An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced.
    http://www.appliance411.com/data.php?rc=548392
    pls rate my suggestion...
    Jun 26, 2009 | Whirlpool Washing Machines
    E1 fault on kenwood dishwasher kdw243a
    error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
    Jan 18, 2009 | Kenwood KW85 Air Conditioner
    Dishwashers Logo
    225 people viewed this question
    Top Dishwashers Experts
