Question about Samsung WF328AAW Front Load Washer
Samsung WF6550S7W Drum not working
I have misplaced my manual. I have a Samsung Moisture Sensor dryer. the power works but the it wont tumble. Model #DV400EWHDWR/AA SERIAL # Y6915AEFB00979F. PLEASE HELP.
Samsung has the manual and a trouble-shooting guide on the product support page: http://www.samsung.com/us/support/owners/product/electric-dryers-dv400ewhd . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201501/20150120165209818/HUDSON_DRY_DV456_DC68-03170A-09_AA.pdf .
Usually if the drum won't tumble, the problem is with the belt, the drum rollers, bearings or shaft that the connect the drum to the motor or the motor.
Can you turn the drum by hand easily? Then look closely at the belt. Replace it if it is damaged. If the drum won't turn, disconnect the belt and check if the drum turns. If it doesn't, check the drum support rollers for wear. Replace all of the support bearings at once if any are faulty. Check the support rollers and shaft at the back of the drum for damage. If you hear a lot of noise as you turn the drum, then the bearings are possibly bad. Check that the plastic slides that stabilize the front of the drum are fine.
Finally check the motor. Replace this if it is faulty. To see a parts diagram and price lists for any parts, see http://www.appliancepartspros.com/parts-for-samsung-dv400ewhdwr-aa-0001.html . Other sites also have the parts for the dryer.
I hope this helps.
Aug 12, 2017 | Samsung Dryers
How do capsules work in a ecco bubble samsung machine
The capsules get tossed into the drum along with the laundry. They dissolve at the beginning of the wash cycle to release an exact amount of detergent for distribution throughout the load.
Apr 19, 2016 | Samsung Washing Machines
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
Mar 15, 2016 | Samsung Xpress SL-C460FW Laser...
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Samsung ecobubble 7kg red drum flashes at end of cycle? Is it broken?
We have later model and have same flashing drum symbol. You need to perform an ECO DRUM CLEAN cycle.
1. Press power to turn on machine.
2. Turn cycle selector to ECO DRUM CLEAN mode
3. Press Start/pause
Mar 01, 2015 | Samsung Washing Machines
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
Samsung front load dryer
I'd investigate a possibly bad starting capacitor for the motor.
Sep 09, 2014 | Samsung DV328AE Electric Dryer
Samsung 3170 reset imaging unit
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
Feb 15, 2012 | Samsung CLX-3170FN All-In-One Laser...
Samsung WF328AAW Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
