Question about Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
Panasonic PT-AE700E projector lamp no longer turns on, instead the fan runs on high for an infinite time until turned off. As well the Power light flashes green after it is turned on. I have no doubt that the problem could be the bulb as it has never been replaced, but could it be some other problem which is not worth fixing?
  • Jason Spotswood May 29, 2013
    As it turns out, the problem was not the projector bulb. I got a replacement and the same problem continued to occur. So if you encounter an issue like this, do not bother replacing the lamp.
    I tried replacing the lamp and it did not fix the problem. Ended up buying a new Panasonic projector.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 21, 2015
SOURCE: PT-D3500E Projector
no havent fixed this problem but also unwilling to pay for advice.
this is something that should have supplied by the contractors who installed and fitted
the said products. many thanks for getting back to me but i will now take this up with the project manager.
Posted on Aug 22, 2008
SOURCE: replaced lamp TYLA1000
IF THE GREEN LIGHT IS FLASHING, THE LAMP COVER HAS NOT BEEN REPLACED PROPERLY. AFTER PUSHING IN THE LAMP SCREW IT DOWN THEN YOU ALSO HAVE TO REPLACE THE BLACK COVER AND SCREW IT IN AS WELL, I ASSUME IT IS BLACK ON ALL MODELS, THEN I REPLACED THE PANEL IN FRONT OF THE LAMP COVER. I DID THIS AND THE GREEN FLASHING LGTS WENT AWAY AND TV CAME BACK.
Posted on Aug 05, 2009
SOURCE: hi, my projector has worked fine until
I also have this same problem, I even fitted new lamp, did yuo get this solved
Posted on Mar 02, 2010
SOURCE: is this blue tinge on the left side of the screen
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
Posted on Jul 07, 2010
  • 55 Answers
SOURCE: red lamp or heat light is flashing while projector
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Posted on Feb 21, 2011
Why does the lamp shut off on the Panasonic PT-AE1000E Projector within 1 minute of starting?
have a nice day!
May 26, 2014 | Panasonic PT-AE1000E Projector Lamp...
Problem panasonic pt 61lc27
have a nice day!
Apr 14, 2014 | Panasonic Office Equipment & Supplies
Where can i get an optical block for a panasonic PT-AE700E and roughly how much am i looking at
USD150 for the Optical block for AE700
have a nice day!
Sep 04, 2013 | Panasonic PT-AE700E Projector Lamp
How to reset panasonic projector ae700
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
have a nice day!
Aug 01, 2012 | Panasonic PT-AE700E Projector Lamp
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does...
May 10, 2010 | Panasonic PT-AE700E Projector Lamp
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
How far to mount projector from screen, screen is a lp morgan rondo
It depends on a lot of factors -- how bright the area is going to be, the size of your screen, etc -- but you'll be roughly 9 to 14 feet from the screen for most settings.
I'm basing this on numbers for a PT-AE700U projector, as I wasn't able to find the AE700E.
Take a look at the ProjectorCentral.com projection calculator if you want to get precise about the distance for your environment.
But be sure to rate my fix as "Helpful" before you click that link! :)
Aug 17, 2009 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Panasonic pt l711u power will not stay on
That used to happen to my PT 711U until I put in a new air filter. After that, no problem.
Dec 28, 2007 | Panasonic PT L711U Multimedia Projector
Panasonic PT-AE700E Projector Lamp Logo
221 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
