Question about Garden
Stihl ms 311
Won't start, intermittent weak spark
  • 11 Answers
SOURCE: NO START
1. has it been sitting?
2.if yes dump out the old gas and what is premixed since it is possibly old, 2 months max.
3. new prem gas and oil mix.
4.press the comp release when starting , was this pressed when you checked compression?
5.if will not sart try a quick blast of WD-40 in carb or a little gas. WD is flammable and will let you know if fuel related. if it fires for a couple seconds then sparks ok and still has gas problem. try one more time and maybe stuck fuel pump flaps in carb will become unstuck. if it runs on WD or small amount of gas in carb but not otherwise, sparks OK. time to rebuild carb check filter and Gas Line.
As always when playing with gas or other Flammables have a Fire Extinguisher ready for the "Expected". Always expect a fire that way you are calm, VERY important if you have spectators.
Safety Guy Bill
Posted on Jan 17, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
  • 4088 Answers
SOURCE: weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Posted on Apr 22, 2010
  • 2239 Answers
SOURCE: hi i have a 019
Not a great Stihl fan, however they usually have a single stop start, choke and half throttle lever, depress the throttle trigger and at the same time pull the lever fully uplet go of the throttle trigger which should now be lock up, this will engage the part throttle and choke, crank the machine until it fires once, then move the lever down one notch and crank again until it fires up.
Posted on May 30, 2011
  • 252 Answers
SOURCE: The Stihl 038 super won't
hi there mwb15
have you made sure the ignition coil is producing enough voltage to fire under compression load ?
you may get a spark at the plug unloaded but under load it may be breaking down / weak making you think its got a fuel problem ?
does your system use a cdi coil system or point/condenser system ?
spark usually falls into weak spark, no spark catergory
if compression , fuel ( you replaced carb) and exhaust are ok , and you have air and vaccuum tight c/cases only things left are timming and spark
remember F A C T S
F = Fuel A = Air & ( air tight c/cases ) C = Compression T = Timming S = Spark
compression should be about 130- 140 approx if in good running order
take a look and let me know
cheers pauly46
Posted on Jun 19, 2011
Part # for spark plug wire on stihl saw model ms 180 c
spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
Jul 30, 2016 | Stihl Garden
Stihl ms 350 doesn't start after running
May have a weak Magneto, in that case. Or you have an air leak thru your oil seals on crankcase.
Dec 27, 2013 | Stihl Garden
Stihl pole saw no spark
Sounds like your coil has gone bad, usually when a coil fails the symptoms are as follows: intermittent spark when engine is hot, then no spark until engine cools down, and eventually no spark at all.
Jul 12, 2013 | Garden
I have a 96 Chevy Corsica and it won't start.... I
If you have a healthy spark (a blue snapping spark), it would not be a problem in the ignition system or the module. An orange, weak, or intermittent spark could point to trouble in the ignition.
I would check the timing on it, maybe it is a timing chain problem. It should have fired and ran a bit with the starter fluid. The fact that it didn't, even with a good spark, well, probably needs a little shop time investigating. Jumped timing from a worn chain? Low compression in one or more cylinders? A couple of things you need to consider.
Good luck.
Mar 31, 2012 | 1996 Chevrolet Corsica
The Stihl 038 super won't start. It is getting too much gas on the spark plug when I try to crank it. Just replaced the carb hoping it was that but still it won't start. The saw was working fine a...
hi there mwb15
remember F A C T S
cheers pauly46
Jun 18, 2011 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
244 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
