Question about Pride Go-Go Elite Traveller 4-Wheel Travel Scooter
What kind of fuse do i need for tiller console fuse for a Pride Go-Go Elite Traveller Plus 4-Wheel
  • 32 Answers
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
Posted on Apr 20, 2009
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
HoverTech
  • 232 Answers
SOURCE: Where can I find a
Contact Pride Mobility at 800-800-8586, they are usually around $20.
Posted on Nov 09, 2010
  • 692 Answers
SOURCE: We have a elite traveller
Take it out of freewheel and see if it will work Next time just wipe it down with a damp cloth instead of washing Washing can cause the brake to rust on the motor case and thats not good also will rust hubs to axles and you won't be able to replace the wheels when they wear down Hope this helps
Posted on Jun 26, 2011
gfreed100
  • 60 Answers
SOURCE: Priderear wheels intermittentant response and sometime fail to engage?
First it could be the brake switch. This switch is located on
the back side of the motor. Its usually apart of the freewheel assembly. This device gives me all kinds of trouble. It can get moist and even wet when you use the scooter outside. This causes the mechanism too get stiff. So i spray it with pure silicon spray. WARNING Do NOT USE WD40 eats some plastics.
IT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
Posted on Aug 16, 2012
How to change wigwag
You will need to unscrew the tiller cover and remove the throttle pot. The lever itself will need the allen screws loosened. Scooter Doctor App
May 19, 2016 | Pride Mobility Products GoGo Elite...
What to do when your go go elite traveller beeps 10 times?
hi, well that 's normally saying the voltage is too high ...
about 28 to 29 volts will flag this error can be a internal controller fault...
Regards
Rob
www.gewizrepairs.co.uk
May 27, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Pride go go elite plus stops when going up inclines
batteries heading for replacement, to much weight, controller fault, are the most lightly suspects.
Aug 19, 2013 | Pride Go Go Elite Traveller Plus HD 4...
I am travelling by air next week and I need to know the serial no. of my scooter. Where do I find this. I have a 4 wheel Go-Go Elite Traveller Plus Hd
hi , its located on the bottom part of the seat stem , you will need to remove the seat and battery pack to see this,
Regards
Jan 25, 2013 | Pride SC53HD GO-GO Elite Traveller Plus HD...
Constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?
place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.
regards
Dec 15, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Can I buy new panels for a Go Go Elite mobility Scooter
Hi Tracy,
Yes, you can buy new shroud panels for this model in red, blue, and silver. Some of the panels, front, rear, side strip, and console, velcro on the chair and can be replaced by the end user. This is model SC54HD for the go go elite traveller plus HD 4 wheel scooter. For about $60 you can get the entire set of panels for a color change.
If I'm not mistaken some of these scooters come to our dealership with the extra panels already in the shipping box. This allows for a quick color change during dealer prep. Call around to several local dealers and see if they have extras available at no charge before purchasing new ones.
Jan 02, 2011 | Pride Go Go Elite Traveller Plus HD 4...
Pride Go-Go Elite Traveller 4-Wheel Travel Scooter Logo
35 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
