Red lines on my tv
Red band across top and bottom of my tv screen.
    Top Expert:
  • Computers & ... Master
  • 75,304 Answers
What is the brand name to your TV? Provide more details please. If you wish to get more details, check the site linked below. It has over 2400 posts now, and all are related to service help to different brand TVs. Pull up older posts there. You can also do a search by the brand name and model number to your device under concern; by type in the brand name and model number to its search box, located at the top right of the display window.
Posted on May 04, 2013
  • james holtzman May 05, 2013
    LG model 50PG20
  • The Knight
    The Knight May 06, 2013
    It seems like the faulty video card, or video processor section circuit to the mother board to your system. Not a monitor problem.
  • 198 Answers
SOURCE: horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Mark_Webber
  • 472 Answers
SOURCE: Dell 2001FP
Chances are the driver tabs inside from the panel to the internal controller board have failed. This is the actual controller board that the internal video card connects to (hidden under the silver cover on the back of the physical panel).
It is not a cheap repair, and it is normally best to source another panel, or just replace the monitor all together.
Posted on Apr 08, 2008
Mark_Webber
  • 472 Answers
SOURCE: Lines across screen
Is it sort of rolling almost.
If so you have a few bad capacitors in the power supply that need to be replaced.
If you dare to venture inside you should see 1 or more buldging caps. (bowing upwards on the top)
If these start to fail, then they will interupt the correct flow of power and cause this problem with your panel.
Easy to fix if you are electronically minded, if not, take it to your local TV tech and it shouln't cost that much to have repaired.
Remember, inside these monitors is high voltage that can kill, even if it's not plugged in.
SOURCE: vertical lines LCD Dell 2001fp
I had the same problem until I decided to go in to figure out what was happening. I am not a technician but I'm a pretty handy engineer...anyway I opened up the panel and separated the big bulky electronics board which is encased in a metal enclosure from the LCD panel itself. After carefully doing so you will find that the electronics which actually control the LCD is covered by a long and thin aluminum plate. This cover can be easily removed by unscrewing 3 or 4 screws. Now here is where the problem arises. I believe that there is one chip (the biggest one you will see) that gets very hot. I measured temperatures in excess of 110 degrees F. It makes sense that temperature is the problem since the lines begin after the panel has been on for some time. My simple solution to this was placing a fan right over this chip. In doing so you wont be able to place back the thin aluminum cover but that's a small price to pay in getting your screen back to normal. The fan should also be small enough for you to put the LCD Panel back together (without this thin aluminum cover). You can hardwire the fan to the Speaker voltage output. I made this fix to my LCD panel about 2 weeks ago and since I haven't seen the lines again. In my opinion Dell knew that this would be a flaw in the LCD because if you notice the power supply for the panel is external which is uncommon in my opinion. The power supply tends to get really hot so in an effort to prolong the life of the panel they made this an external attachment. Well this obviously didn't solve the problem and they went ahead and put it out into the market. If you would like more details send me an email at Mike28ML(at)optonline.net Good luck, with this issue cus I know it way annoying the hell out of me.
Posted on Oct 02, 2009
taran_2005
  • 10515 Answers
SOURCE: After about a year of working normally, my monitor
As this question is still open, wanted to confirm - Did it resolved the problem or would you like to have any added information.
If NO, kindly accept the solution and close the thread and if YES, revert and i would be able to follow up.
Thanks and Regards
taran_2005
Posted on Dec 30, 2010
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Mitsubishi 55411 projection tv has red band across bottom
go into the customer menu and select convergence with the original remote; if either the red or blue will not move in some direction, you have a bad convergence IC(the WS-55411 uses two STK-392-110 CONVERGENCE IC chips)
Aug 12, 2009 | Televison & Video
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
