Question about Motorola FV500 2-Way Radio
Motorola FV500 2 way radio can send/cant receive
My Motorola FV500 can send transmissions without incident. BUT it has stopped receiving incoming messages. Any suggestions?
  • tmar Aug 10, 2007
    No QT on either, thanks for the suggestion.
    When I hold down the Monitor button I hear no static. I hear nothing on this handset, yet others can hear me perfectly through theirs. Thanks for the ideas.
    This has been a good handset for us (we use it in our warehouse instead of the old speaker system). I guess I should just purchase a few more handsets. Will other, newer Motorola models work with an older one like this?
  • 123 Answers
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Posted on Aug 10, 2007
  • Ernesto  Garcia
    Ernesto Garcia Aug 10, 2007
    seems like the internal speaker is not working
    try to attach and audio accesory, may be the jack is dirt or something.
    in some cases when you plug the the audio accesory the problem can be solved.
    Problem Solver:
  • 20 Answers
I'm with Neto on this one. It coul be just a problem with "tones". I'm not familiar with that exact model but check for a "monitor" button. If you have one on the radio... press it down.... this should open up the squelch completely. You should hear static.... thats what you want... basically you will hear everything that transmitted on that channel (frequency) regardless of privacy codes (tones). You can also do the same thing by turning the squelch all the way down to 0 ( as Neto was suggesting). The monitor button is more convient but if you don't have that function do as Neto said and turn the squelch down all the way. Once the squech is turned down or monitor button is engaged you should be able to hear everything transmitted on that channel including static (rushing sound). With the squelch turned down or monitor button pushed, try transmitting on the problem radio... if you can hear the problem radio easily with monitor button pushed or squelch turned down then the privacy codes (tones) are set differently on each radio. You want the privacy codes to be the same on both radios otherwise you won't hear any rx audio or the transmitted audio.
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Send/receive error on 'Microsoft Outlook'
first of all check if you are using the correct account information which include incomming and outgoing mail servers.
secondly disable the firewall of the norton in the norton settings
Jun 23, 2009 | Norton Internet Security 2005...
Motorola razr v3. not receiving incoming texts
this is somethng you will need to contact your cell provider about they re the ones to fix this
Mar 30, 2009 | Motorola Mobility RAZR V3
Sub channels and how to turn them on
Beg to differ with your friend. Those small numbers are not sub-channels but rather are Interference Eliminator Codes. The represent what code is being used by the radio to eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the+ or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Motorola Talkabout T5100 (14 Channels)...
Motorola Talkabout T5700 and Audiovox GMRS 1582CH don't talk
Most radios of this series would have Interference Eliminator Codes. The codes eliminate other incoming transmission not with the same code (number). There could be similar radios working on the same channel/frequency, but if they do not have the same code then neither one would hear each other. This does not make a channel "private", rather it limits what one can hear on that channel to another radio with an identical setting of the code. In some Motorola models, pressing the Menu button until the small numbers/code flashes would enable them to be changed. To change, press the + or - keys. Pressing the MON key or setting the code to Zero would enable the radio to receive and sound off all incoming signals with or without the code.
Nov 15, 2008 | Radio Communications
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Motorola and Kenwood compatibility....
Hello!! First of all, any radio in the right frequency will work with any other, to work just need the following features: -Frequency, 154.700 which is correct as you said. - the Squelch code, this could be PL or DPL. The XV2100 has a table of codes that you can try, as you dont know this code form the Kenwood, you will need to check one by one. If you have the chance to send the Kenwood to some to "Read" the radio parameters( freq.,Code, ETc) you can look those parameters on the XV. Hope this can help, any comments neto-rola@hotmail.com Good Luck
Jan 20, 2007 | Motorola XV2100 (1 Channel) 2-Way Radio
Motorola FV500 2-Way Radio Logo
532 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
