Question about LG 42LM6200 42 in. 3D LCD HD Cinema Smart TV
Lg tv picture settings - LG 42LM6200 42 in. 3D LCD HD Cinema Smart TV
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
Picture too wide on tv
Sounds like you have the "Wide" mode set to Zoom or wide zoom. Also if you are on Comcast cable the cable box has a setting of Zoom and full. Set your TV's zoom setting to "Full" and the cable box to Full. I don't have an LG so you'll have to find these settings yourself..
Feb 25, 2015 | LG 47LM6700 47" Class FuHD 1080p LED LCD...
Why does my lg tv seem to be stuck on a zoom setting?
Find the Aspect ratio button on the TV remote. Press it a number of times to cycle through the options. Stop when the picture is the shape you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Check the picture aspect settings in the Uverse set up menus. Make sure the option selected matches the shape of your TV.
Sep 07, 2014 | LG 42SL9000 42 in. HD-Ready LED TV
I have an lg golden eye tv.....can see the picture perfectly except for 3-4 inches of black runnin down both sides that curves in...how can i fix it
Try changing the tv picture settings to 16:9 ratio or widescreen/letterbox setting!! Menu > picture> newer lg's also have a quick menu button on the remote. Hope u sort it.
Feb 23, 2011 | LG Televison & Video
LG 42 inch picture does not fit on the tv screen horizontally
The format is set incorrectly. Go into the Picture settings in the menu and adjust the format settings until you get the size picture that you like.
Craig
May 08, 2009 | LG 42PX5D 42 in. Plasma HDTV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
New LG 50" Plasma with picture problems
Check the menu for ,probly under settings called convergence,, if it has it ,,that will make it right,, it realines the colors,,soposed to do it periodically,, or when you move the .tv. well ,,good luck with that
Oct 05, 2008 | LG 50PX4DR 50 in. Plasma TV
PICTIRE SETTINGS
1. you should have a HD source, such as direct tv with HD channels
2. You need to connect this source with a HDMI cable
3. Make sure all the setting match from the source to the tv
May 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
LG 42LM6200 42 in. 3D LCD HD Cinema Smart TV Logo
56 people viewed this question
Computer Repairing
Computer Repairing
