My usb port wont work.i dont know why? - Computers & Internet
  • 3,799 Answers
Install the correct drivers and make sure the ports are correctly connected to the mainboard.
Posted on Jun 17, 2013
Benimur
  • 6966 Answers
SOURCE: Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jun 01, 2007
DRSS
  • 81 Answers
SOURCE: usb not working
Hi FRND,
I hope you have the P4 machine with the front USB connections….
First you have to know the wire connection and voltage…
Four wires are their...
Red: + 5V / Voltage + / VCC
White: USB - / Data - / D -
Green: USB + / Data + / D +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current
  1. Red
  2. white
  3. green
  4. black
It you still have confusion then look at the link…..
http://www.frontx.com/cpx108_2.html
Posted on Dec 06, 2007
map9966
  • 2351 Answers
SOURCE: usb ports not working
Hi stilla, when you were in the device manager did you notice any yellow ! points? This is important for me to know, & will come in handy for re-installing you're audio driver software.
Since you setup this board I'm guessing you installed Windows XP (Home or Pro). (If you installed any version of Vista let me know because Vista is famous for loosing USB ports & CD-ROM drives). Vista will need other suggestive steps to repair.
It is suggested that you run windows update service. This is needed not only for security patches but also for USB ports and other devices connected to you're system. I'm hoping after you updating windows you're USB's will function. When installing update & you will come across .Net framework versions, please install only one at a time. Please do not sip any because there are updates for the update. When you finish updating you're system through windows update service, do not install service pack 3. Wait until these other problem has been addressed.
After the last Win update restart the system (Even if windows does not ask you to). Go back into & run windows update service again. (Choose Custom update this time).
After windows finishes checking you're system, look to the left side of the page. You are looking for hardware updates. If there are some, download & install. Next, restart you're PC and enter the bios. (Press the delete key every 2 seconds until the bios main menu opens). Set Plug & play OS to No. This will be within the Advanced menu.
This allows the bios to set Irq’s & DMA's instead of windows for the basic input & outputs of the motherboard. Pages 2-11 in you’re manual. (This has nothing to do with speeding up or slowing down the computer).
Click on this link. http://support.asus.com/download/download.aspx?modelname=A7N8X-VM&SLanguage=en-us
This will load Asus drive site for you're A7N8X-VM board. Click the + sign next to Audio. Create a folder on you're desktop & name it Realtek. Download the driver for you're OS & save the driver in the folder you created. The file alc650_wdma341.zip is compressed. You will need to uncompress the file & keep the uncompressed files within the same folder. If you do not have WinZip you can download a free 45 day trial version into you're PC. Free download:
http://www.download.com/WinZip/3000-2250_4-10003164.html
Once WinZip is installed right click once on the file alc650_wdma341.zip. A pop-up window will open, slide down to WinZip & left click, Extract to here. Open add/remove programs. Uninstall the sound driver AC'97. Restart you're PC. When windows finishes loading, open device manager. If there is a yellow ! point within Sound, audio and game controller, right click on it once. Than left click update driver. Windows hardware wizard will load. In the first window click No, not at this time. Click next. Click the circle, Install from a list or specific location & click next. Click in the box Search removable media, (This will remove the green check mark).
Than click the Browse button. Go to & open the folder you created (Realtek).
Click once on the folder WDM, than click OK. The downloaded driver software should install.
Windows sometimes just doesn't install some devices as it should & installing through device manager seems to work much better. Close all opened windows & restart you're PC. If you're sound still does not function than the onboard, integrated sound chip is defective or you're speakers are bad. You're board is beyond Asus 3 year warranty period. You will have to buy a PCI sound card to regain sound for you're system. I can suggest a replacement sound card from these links.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=290241
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1567045&CatId=2771
Please let me know if the above suggestions have made a difference? Post any errors, problem or failures. If anything does not go well, explain what did not work so I can possibly help you farther. It's my goal to get you're system to function.
Good Luck!
Mike
Posted on May 15, 2008
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Posted on Dec 07, 2008
Nic61
  • 1073 Answers
SOURCE: why wont my front usb ports work
My guess is that the cable from the front usb isent connected properly since everything els working from the front
Want to learn about USB, on off and security
drag down the upper portion of your mobile phone the touch on usb connected then press on mass storage but first connect your usb to your pc
Mar 24, 2014 | Dell 14Z-N411Z
Advanced Micro Devices ATI I/O Communications Processor USB 2.0 EHCI controller driver so usb ports will work
Would you please check the device status in the Device Manager? Is there any yellow triangle box with an exclamation mark in it?
Mar 02, 2014 | Advanced Micro Devices ATI I/O...
Asus altel
It would be helpful if we knew the Asus model, the OS you are using and what size the USB is and what is the File format on it? I would suspect it's the File on the USB, not the Computer.
May 04, 2013 | Computers & Internet
I have ipod nano 1st gen and my ipod wont detect by itunes even my explorer using USB 2.0, i have firewire port wall charger when i try to plug it it charge but idont know if it will work to computer cause...
There might be a few issues here:
1. Your ipod software needs to be updated
2. Your usb cord is bad
3. Your usb port is not working properly
Either find someone that has a firewire port and update it via itunes, or use someone elses computer to update your ipod's software.
www.huskyipodrepair.com
http://repair-scratched-ipods.blogspot.com
Jan 26, 2010 | Apple iPod nano
Usb ports dont work past boot up and pc boots into menu where you have to select wether or not to run in safe mode. And since the usb ports dont work i cant select. I tried switchig the ram. and i tried...
Familar with the bios?
Check that usb is enabled in bios and to boot to usb devices.
You may need an older keyboard or non usb keyboard to get you restarted.
Jan 04, 2010 | Computers & Internet
Usb ports loose and now wont work
Even taking a laptop apart (to board level) is tough, but you need to order the USB socket on ebay and solder the new one in carefully. Are you a qualified miniature soldering expert?
Jun 30, 2009 | Dell Inspiron 8600 Notebook
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
The orange light on my usb wont turn on. it was working just fine 2 days ago. after my last use i put it on top of my dresser and never touched it. Can someone please identify the problem when the orange...
Very good in checking if your computers' USB ports are working. Now that you know that your computer's USB ports are working, try your USB device on his computer and check if it'll work there. If it also doesn't work there, then it'll be your USB device that's not being read.
Jan 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer wont recognize usb drive
try to use another connector! and try connecting it to other USB ports!
Dec 06, 2007 | Quantum Fireball Lct15 (QML20000LC-A) 20...
LG and Vista
Hi vista shouldnt be the problem do you have the software for your phone installed on your comp as i have come across loads of problems with people not having the right software for their phone let me know if this is the case.
The one problem i did have with the usb port is when i was trying to use one of the ports i kept getting errors and i tried everything to solve it but to no luck,
Then the next day i plugged the usb into another port and found that it worked and to this day that one prot wont accept my phone but the other will, i dont know why but using the other port worked.
Let me know how you get on ok
Nov 26, 2007 | LG KG800 Cellular Phone
Computers & Internet Logo
David Payne
David Payne
