Question about Samsung DynaFlat TX-P2775H 27" TV
TV I believe this is the correct model. I was watching TV last night and I muted the TV. Then the screen went dark, and I got a message in bright green AV 1. I am connected to Comcast. I can't get the TV to do anything.
  • pinkgirl Aug 11, 2007
    Thank you so much!! I had to play around with the menu on the TV but if worked!! Thank you. Donna
  • 398 Answers
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
Posted on Aug 11, 2007
SOURCE:
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
I have a 50 inch panasonic 720 plasma tv and while watching it last night a large black box with white writing came on in the top right corner of the screen with mute in it and the sound went off. I...
Unplug the TV. Replug in the TV. If it's still there, you probably have a bad panel. Try changing inputs. These panels are non-repairable.
Jun 16, 2011 | Televison & Video
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Discoloration problems
covergence problem, most likely the ic's are bad, call a repair man!
Aug 27, 2009 | Televison & Video
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Lost picture, sound fine Sanyo ds19310
are you seeing bright white lines along with blue colour please clarify so I can give you the best solution
Sep 12, 2007 | Sanyo DS19310 19" TV
P42W46X
take visa or mastercard to local best buy for new tv. sorry
May 26, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
My tv screen goes green and then turns off by itself
mine does that to but when i turn it on its blue and in like 5sec. turns off by its self
Nov 09, 2006 | Premier Mounts Universal Flat Panel Wall...
Samsung DynaFlat TX-P2775H 27" TV Logo
208 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
