Question about Korg D4 4Track Digital Recorder
Korg d4 when i bounce tracks the pan settings have all become centered.How can i overcome this please.
How to recover deleted data
you can obtain undelet software to do this but do not use the machine too much before attempting the procedure, too much use might lead to the areas where data was stored becoming written over. If the data was very important I would contact a data recovery specialist, one with a proven track record.
Good Luck
May 27, 2015 | Korg D3200 Digital Studio
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
How do i play my recorder through my practice amp?
try using an adapter that fits into the headphone of the d4 and connects to a jack plug like on a guitar lead.most appliance stores should have these.
Aug 31, 2011 | Korg D4 4Track Digital Recorder
How to turn on en off the moulation of a korg x5d
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Jul 28, 2011 | Korg X5d
Track is stuck on 1.5 new track is 2.5
If you can save what you have do it. Then reinitalize the unit.
Jul 08, 2011 | Korg D4 4Track Digital Recorder
I can't get any sound out of my Korg Mini Kaoss pad when running it into an amplifier. It works fine if I run it into my old cassette 4-track recorder, but I get nothing other wise. I've tried bunches of...
The Mini KP generates Stereo output and you would run it to either a stereo channel on your mixer before the amp or into two channels of your mixer board and PAN them to opposite sides.
If you try to connect this to a monaural amp, like a guitar amp) your cable will ground out the output of this box. The minimum would be to builld a special resistive mixer to combine the channels before they go to your amp HOWEVER you will lose much of the effects without having a stereo system.
Jan 19, 2011 | Korg Mini Kp Kaoss Pad
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 | Music
The left/mono output of my korg trinity is lower volume than the right..also the head phone output is a bit crackly?
The output jacks sometimes become disloged from the circuit boards,
also make sure that the pan is set to 50/50
Dec 04, 2009 | Music
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
Korg D4 4Track Digital Recorder Logo
19 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
