Question about Cycling
Echo-f1 setup instuctions pls help
Just need to know how to set the rim size or what each function means thanks
map9966
  • 2351 Answers
SOURCE: Problem: set wrong jump Cmos
Do you still have you're manual?
Go to page 1.18.
If the bios jumper is not over pin 1 & 2, than make it so.
While the jumper is on 2 & 3 you're bios clears it's self every time you boot the system. (This is why you're clock does not keep the correct time.)
Need manual? Click on the link. http://support.asus.com/download/download.aspx?modelname=P4P800-MX&SLanguage=en-us
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 24, 2008
  • 6982 Answers
SOURCE: need chrome rims. What size do I need ? Thanks
There should be a sticker on the door near the latch with tire sizes recommended for that vehicle. last # is wheel size (14, 15, etc) This is also the size on the tire itself (205-75-15 is a 15" wheel) Then all you need is to match the bolt pattern. Any wheel retailer knows correct size or buy from someone who has same vehicle. Don't exceed recommended tire sizes unless you intend to also change speedometer to match the new final drive ratio.
Posted on Mar 31, 2009
trackrash
  • 10 Answers
SOURCE: Bent rims
You have some options. Many rims have the size stamped on the rim. You may have to remove it to find it. There are several web sites that sell use or new wheels. You could look through their catalogs an find a match. I have also gone to the junk yard and found a match for a car I used to own.
You could measure the wheel, but that doesn't mean that every rim that size would fit your car.
Posted on Jun 17, 2009
  • 13 Answers
SOURCE: Does anybody knows what size of a tire or rims
Hi. The original equipment tire size is 235/55r17, with a 17x8 wheel size. Up one tire size in a 17 inch is 255/50r17, with nearly the same circumference, but much wider and more sidewall profile. Up one (referred to as "plus one") wheel size, 18x9 inch, would be a 235/50r18. Down one tire size is 215/60r17 with narrower tread width and much more sidewall height. With B-mer's engineering you have quite a bit of leeway with larger tires and wheels, more than most manufacturers. There is lots of software on wheel seller sites that will let you see different tire wheel combinations on your vehicle. Check them out. Hope this helped!
Posted on Sep 11, 2009
Molson02536
  • 3854 Answers
SOURCE: i need to know stock rim size and what will fit 1986 vw scirocco?
Rims
  • 15x7
  • Offset 33mm
  • Backspacing 5.41"
  • Bolt pattern 4-100
  • Tire size 195/50-15
Rims
  • 14x6
  • Offset 38mm
  • Backspace 5.02"
  • Tire size 185/60-14
You can also go 16 inch, keep me posted and i can let you know what 16 inch rims will work.
Posted on Nov 04, 2009
How do we set up echo to our home Internet?
to setup the Amazon Echo you need its Amazon echo app from the google playstore app normally the echo will tell you how to do so on its own if it is your first time setting the device up
Jan 08, 2017 | home Audio Players & Recorders
What is f1
if its a whirlpool built product it usually means that the main control board has failed... what brand is it?
Jul 24, 2016 | Washing Machines
How can I enter service mode in panasonic workio dp 2330 to set new developer. Pls advise
To enter service mode press FUNCTION, ORIGINAL SIZE (LEDGER/A3) and 3 keys simultaneously then F1 will appear. Press 8 on key pad and F8 will appear, press start, select 09 then ok or start and this will run developer for a few minutes. when done press FUNCTION and C (CLEAR) keys to exit service mode.
Jul 17, 2011 | Panasonic Office Equipment & Supplies
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
Echo on my end when someone calls! Please help! Thanks!
it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
I have another computer that won't start. the screen says - missing \windows\systems32\config\system use original setup cd rom select r to start repair I tried but it doesn't work
you need bootable windows disk or recovery disk.
Then set first boot device as your cd or dvd rom.
when you power up the computer press F1 or F2 or "del" key to enter in bios then go to boot option then save settings.
thenh put cd in cd /dvd rom then it boot with disk.
Then it load some file wait for 5-7 minutes then it gives screen then press enter.
then followe the instuction.
Aug 08, 2009 | Computers & Internet
Question on rims on a 1988 IrocZ28. the front rims have a stamp on them indicating 'front' and the back rims 'rear'. the tire size that came on the car when I bought it are P245/50/R16 (96T-mts). Im pretty...
Those wheels are what is referred to as "staggered" meaning different sizes front and rear. If you measure the width of the wheels the rear ones will be wider. I'm not sure what size you are supposed to be using but the rears should be wider. This kind of setup is not designed to be rotated. You could rotate side to side but this won't even your wear out.
Aug 08, 2009 | 1988 Chevrolet Camaro
Bent rims
Jun 17, 2009 | 2001 Dodge Stratus
Canon imagerunner Ir c3200 total reset
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Nov 12, 2008 | Canon imageRUNNER C3200 Color Printer
Hi i want to widen my screen
The Resolution can be changed in Windows XP by minimizing all applications, right clicking on the desktop, selecting Properties. In the Display Settings window go to the Settings tab. Here you can change the resolution. I think you are wanting to use a widescreen setup so going for a resolution of 1280x800 should fill your screen. Play around with the available settings to resize the screen.
If you are using MS Vista, you need to minimize all applications to the desktop, right click, select Personalize. In the Personalize Window click on Display Settings down the bottom, modify the resolution as appropriate.
Alternatively, you may be able to find the function key that did this to your resolution. Above your F1-F12 keys there should be a little picture. If you click on the [fn] key (near the Windows key) as well as one of the F1-F12 keys you can cause different functions to be performed. This may be how the resolution changed initially.
Good luck
Apr 23, 2008 | Toshiba Satellite A35-S159 Notebook
Cycling Logo
65 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
