Rinnia econoheat 850 pilot light lights but burners wont stay lit
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
protek480
  • 1714 Answers
SOURCE: pilot light is lit, burner will not come on
The thermocouple must be in the flame of the pilot and producing a signal to the gas valve. Also check thermostat
Posted on Jul 18, 2009
  • 33 Answers
SOURCE: pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
  • 30 Answers
SOURCE: ventless gas wall heater. Pilot lights but wont stay lit.
The thermocouple may be worn out.
The thermocouple may have come loose from the valve.
The ODS pilot may be clogged with dust or lint and may need to be cleaned with air(less than 30psi)
The valve or regulator may be faulty.
Posted on Mar 04, 2010
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 27, 2011 | Water Heaters
The pilot light will stay lit. Go to turn on heater and stays on briefly and goes out The heater wont stay lit.
If the fan comes on and blows out the pilot light then you need a new furnace because that's the sign of a crack in the heat exchanger. Need a little better description. Do the burners light then the fan come`s on and then it goes out completely?
Nov 24, 2010 | Heating & Cooling
I can't get the pilot light on my furnace to stay lit.
take out the pilot assembly. there is a small burner and an orfice. the orfice does get clogged if it has not been operated for awhile. you can clean it out with a small sewing needle. if the pilot wont light or stay lit, replace the thermocouple.
Dec 06, 2009 | Heating & Cooling
The burner will only stay lit for a few minutes
Hello. Begin by using a small brush to clean everything in that area. Then light the pilot and light the burner. If it still acts up, change the thermocouple. Regards, joe
Nov 22, 2009 | Computers & Internet
Burner not staying lit on rinnia rice cooker
If the rice pot is not in, burner will not light.
if that's not the case
Replace the thermal sensing unit
Nov 16, 2009 | Rinnai RER-55AS 55-Cup Rice Cooker
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
