Question about Coffee Makers & Espresso Machines
Black Decker Manual easy brew CM 55 coffee machine
Lost manual on how to use
SOURCE: Black and Decker Coffee Maker DE790B
There is nothing wrong with your unit, This is not a problem. There is no burner at all. This is a thermal carafe unit that does not require a burner to keep the coffee hot, but rather it's the thermos like quality of the carafe that keeps the coffee hot.
Posted on Jan 03, 2009
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
SOURCE: My Black and Decker Spacemaker coffee Maker will
We had this same problem and it turned out that the inside if display and circuit board caught on fire and melted inside. File a report with the USCPSC and call Black and Decker. They are sending us a new model free of charge but they are also telling me to send them the coffee pot free of charge wtih postage paid. I refuse to do this for 30 days because the Consumer Product safety commission wants me to keep it for 30 days to investigate
Posted on Nov 11, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: On but won't brew
The heating element may have failed or a connection has worked loose. Chances are slim you'd find anyone even willing to look at one of these. It would cost more to repair than replace.
Posted on Apr 10, 2010
SOURCE: Need owners manual for a Black & Decker DLX900 12-Cup Coffee Make
I need to program my coffee maker to come on in the morning, I have lost my manual
Posted on Jun 15, 2010
Black decker user manuals
Do a web search and type Black and Decker manuals into the box. Most companies post pdf copies of all their manuals on line. This saves them the trouble of having to send them to you.
Sep 01, 2014 | Black & Decker Brew N Go DCM18 Coffee...
Lost my manual for the model cm1050w
I searched the black and decker website and couldnt find a copy of the manual you might want to contact them directly to get a copy of some help at: homeappliancesupport@spectrumbrands.com
i got this email from their website
Dec 26, 2013 | Black & Decker Coffee Makers & Espresso...
Instructions in manual for programming brew time is incorrect
Here's the Black & Decker products page where you can find another manual.
Here is a list of all their supported coffee makers.
http://www.blackanddeckerappliances.com/products/coffee-and-tea/coffee-and-tea-makers.aspx#/?page=1&filter.brand=Black%20and%20Decker&filter.categorytier2=Coffee%20and%20Tea&filter.categorytier3=Coffee%20and%20Tea%20Makers
If linking directly to a search result dosn't work use this link and enter, Coffee Maker, in the search box.
http://www.blackanddecker.com/Products-Accessories.aspx
Dec 16, 2013 | Black & Decker CM1050B
Need user guide for discontinued Black and Decker CM 10 cuppa cino coffee maker
Hello, unfortunately it is nearly impossible to find an existing manual. however I had great success using the methods outlined in the article. All the best. How to Use Black Decker Cappuccino Maker eHow
Mar 08, 2013 | Black & Decker Coffee Makers & Espresso...
How do I program a Black and Decker Smart Brew Deluxe coffee maker?
http://www.useandcaremanuals.com/pdf/DCM2500,DCM2500B,DCM2500K884.pdf Here's a link to the manual Mjd944
May 08, 2012 | Black & Decker Coffee Makers & Espresso...
How do I program my coffee pot to start brewing at a certain time...I lost the manual and can't figure it out...
Go to this website:
http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Enter your model number and click on search. If the search function does not produce a Use & Care Manual for your model try manually searching the list o ther page below for a similar model.
Follow the programming instruction in your Use & Care Guide.
Mar 08, 2011 | Black & Decker 12-Cup Programmable...
Feb 18, 2009 | Black & Decker DLX900 12-Cup Coffee Maker
Black & Decker TCM800 won't go all the way through brewing cycle
I have the TCM700 and it would turn off before the brew completed.  This was because it had some sort of buildup from use.  The manual recommended to brew with white vinager and water.  The exact mix was in the manual, but my wife just did all vinager.  Worked great.
Nov 26, 2008 | Black & Decker TCM700 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
148 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
