Question about QMobile Chinese Recipes
Default Codes default code for reset
Reset my password code
You can try using default code ....If the default code not works use master reset code and reset it..For Nokia 12345 or 12345 or 0000 are default codes.
if these code does not works get free master reset code from
Unlocking4free.com and reset nokia DCT phones and alcatel old phones from security code.
Oct 27, 2012 | Cell Phones
Tip
Service codes Chinese models
  1. Service codes "Chinese" models:
  2. default user code: 1122, 3344, 1234, 5678
  3. Engineer mode: *#110*01#
  4. Factory mode: *#987#
  5. Enable test mode COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
  6. Restore factory settings: *#987*99#
  7. LCD contrast: *#369#
  8. software version: *#800#
  9. software version: *#900#
  10. Service codes BenQ:
  11. software version: *#300#
  12. test mode: *#302*20040615#
  13. Service codes Pantech:
  14. software version: *01763*79837#
  15. service menu: *01763*476#
  16. reset defaults (phone/user code reset to default): *01763*737381#
  17. Service codes VK-Mobile 3xx, 5xx:
  18. software version: *#79#
  19. software version: *#837#
  20. service menu: *#85*364# (hold #)
  21. Service codes VK200, VK2000, VK2010, VK2020, VK4000:
  22. software version: *#79#
  23. service menu: *#9998*8336# (hold #)
  24. reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
  25. Service codes LG:
  26. software version: 2945#*#
  27. Service codes Sony-Ericsson:
  28. J100 software version: #82#
  29. Service codes Fly:
  30. M100 software version: ####0000#
  31. 2040(i) reset defaults: *#987*99# Send
  32. MX200 reset defaults: *#987*99# Send
  33. MX200 software version: *#900# Send
  34. SL300m reset defaults: *#987*99# Send
  35. SL300m software version: *#900# Send
  36. SL500m reset defaults: *#987*99# Send
  37. SL500m software version: *#900# Send
  38. MP500 reset defaults: *#987*99# Send
  39. MP500 software version: *#900# Send
  40. Set language to English: *#0044#
  41. Set language to Russian: *#0007#
  42. Service codes Konka:
  43. C926 software version: *320# Send
  44. C926 set default language: *#0000# Send
  45. C926 set English language: *#0044# Send
  46. Service codes GStar:
  47. GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
  48. Set language to English: *#0044#
  49. Set language to Russian: *#0007#
  50. Service codes Motorola:
  51. Motofone F3 software version: **9999* Send
  52. C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
  53. C138, C139, C140 software version: #02#*
  54. C155, C156, C157 software version: #02#*
  55. C257, C261 software version: #02#*
  56. V171, V172, V173 software version: #02#*
  57. V175, V176, V176 software version: #02#*
  58. C168, W220 software version: *#**837#
  59. W208, W375 software version: #02#*
on Mar 07, 2010 | Cell Phones
Tip
CHINA PHONES CODES
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile
china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
set English language (new firmware): *#001# Send
also
Service codes BenQ:
Service codes 3xx, 5xx:
Service codes LG:
Service codes Fly:
ZTE Mobileyahoo15.gif1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatelyahoo15.gifE205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes BenQ:
Service codes LG:
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly:
Service codes Motofone-F3:
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
and "yes"''
-mobile Inno30, 55, 89, 90, 99, 100, A10, A20, P10, Vk200
- Set full factory *741*737381#
- Set full factory *741*7373868#
- Set full factory *741*2878#
- Set Engineer Mode *888*888#
- Check software version *888*837#
I-mobile 100 ,200 , 313
- Check software version #*888#
I-mobile 309, 310
- Check software version *0*4636#
- Test Mode *0*6268#
I-mobile 311
- Check software version #*878#
I-mobile 511
- Check software version *1222*1#
I-mobile 301, 302,308, 508, 601, 602, 603, 604, 606, 611, 901, 902
- Check software version *#159#
- Set Factory Mode *#32787#
- Set Engineer Mode *#3646633#
I-mobile 503, 506, 605, 600, 607, 608
- Set Engineer Mode ***503#
- Set Factory Mode ***504#
- Set Auto Test ***505#
I-mobile 509, 612
- Set Factory Mode *#66*#
I-mobile 504, 505, 803
- Check software version *68*48#
- Set full factory *789#
- Test Mode *#789#
I-mobile 305, 306, 315, 510, 609, 609i,516
- Check software version *#8375#
- Set Factory Mode 878
I-mobile 610
- Check software version *#22#
I-mobile J101, J102
- Test Mode *23638777*783781#
I-mobile 502, 502i, 505, k9, 802
- Check software version *201206*4636#
on Mar 11, 2008 | Nokia N95 Cellular Phone
Cellphone's default password
What type of samsung are you having:- For default reset codes Samsung A300, A800_work with this code *2767*637#, then Samsung S100, S300, V200_*2767*7822573738#.
By the way do you want reset codes or what??
Sep 13, 2012 | Samsung Cell Phones
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
Service codes BenQ:
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
How will i open my nokia 3410 cellphone?i forgot the security code of it..
try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Unlocking4U.com.
Apr 17, 2012 | Nokia 3410 Cellular Phone
Unlock personal pin
try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Mobileunlocksolutions.com .
Mar 25, 2012 | Cell Phones
How to default nokia code
what code you need? try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Unlocking4Free.com.
Feb 01, 2012 | Cell Phones
Phone lock code
try resetting it
Sep 05, 2011 | Cell Phones
QMobile Chinese Recipes Logo
70 people viewed this question
Top QMobile Apps Experts
Are you a QMobile App Expert? Answer questions, earn points and help others
