Question about Siemens WM5487A Front Load Washer
F34 Door is now open but the machine wont wash on any cycle. F34 message remains flashing.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
F34 nad f36 error bosch washing machine
Check/ clean filter bottom R/H side could be dirty. Sometimes can be hard to remove to clean take it easy with it it can be quite Brittle plastic
Feb 02, 2015 | Bosch Washing Machines
What does erroe code f34
F34 is a motor error
and can mean many things from a blasted contact not so good
or brushes or a bad motor detect on the pump
Aug 05, 2014 | Siemens Washing Machines
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
An error F34 how can i solve this problem
Hi and welcome to FixYa, I am Kelly
Somehow you selected a clean cycle.
http://maytag.custhelp.com/app/answers/detail/a_id/2892/~/display-shows-rl-or-f34---front-load-washer
This error code indicates that items were detected in the washer during the Clean Washer cycle.
The Clean Washer cycle is used to keep the washer fresh and clean. Do not place garments or other items in the washer during the Clean Washer cycle. Use this cycle with an empty washer basket.
If you have a Maytag.... (no model number given so I chose one)
See the Use and Care Guide for details; find it by entering your model number in the search tool below.
Remove the items from the washer.
To remove the error display, press Pause/Off or Pause/Cancel or Power once.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Washing Machines
Door wont open and F34 error message on our axxis front loader
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
Sep 27, 2008 | Bosch Washing Machines
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
Siemens WM5487A Front Load Washer Logo
77 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
