Question about Hyundai X93W 19 inch Monitor
How open the monitor - Hyundai X93W 19 inch Monitor
Open and repair
There is one way you can open a monitor. You need to get a flat, sharp tool like a knife or a flat screw driver and you open your monitor from the bottom working your way to the top around the monitor. Take note of the finger-like clips that clip the cover to the monitor itself, make sure you notice how they clip so that you do not destroy them, they are the only things holding your monitor together. Its as simple as that. I hope you will find help in this article
Sep 24, 2013 | Computers & Internet
MY MONITER IS NOT WORKING.IT NEED VIDEO CARD. HOW CAN OPEN MY MONITER?
i think video card can be inserted in cpu not in monitor
is this true
Jun 18, 2012 | HP 2159M Monitor
How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Dec 21, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I usually dual monitor and have programs open on both. now that i am at home i do not have my second monitor only my laptop. when i go to open a certain program it opens on my "second monitor" that isnt...
You should go to the display properties on your laptop while at home and disable the dual monitor setting. You should then have all programs open on your laptop screen and not on the secondary monitor. If running XP, right click an open spot on desktop and select Properties. If running Vista, right click an open spot on desktop and select Personalize. Go to Display Settings, select the second monitor and uncheck "Extend the desktop onto this monitor". Hope this helps.
Apr 25, 2009 | Computers & Internet
How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Please tell me, how to disassemble it.
Please do not Open a Monitor, If the issue Exists with the Display Try with another Monitor ... If the same issue exist on more than one Monitor, then Troubleshoot your computer to fix it.
If the second Monitor does great then Service/Replace the monitor.
Opening the Monitor could Void the warranty if you have one upon it.
Jul 14, 2008 | ViewSonic VX924 19" LCD Monitor
How to open the casing of my LCD Monitor Model HP w 1907v
I have a problem of opening the casing of my LCD Monitor, I want to open it so that I can visually check inside.
Jun 19, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
Pls tell me how to open monitor for repair
Protocol Internet Caf'e
AL SALAMAH ST. JEDDAH
I also opened the cover of monitor but its really hard because the two clips hold it tight from the top of monitor. First I open the 2 screws at the back. Then you have to hold the cover very strong and its strongly to left and right like you are ripping it till and the cover gets free from the clips at left and right parts.Than when you look at the top of monitor, you will see little holes at the left and right sides of monitor. you will have to free them with a screwdriver. ( its mostly possible that there will remains some track:) i have 40 samsung monitor here in my cafe so plz guide me to open the cover of monitor. call me my no. 0564993626
May 14, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
Hyundai X93W 19 inch Monitor Logo
26 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
