Question about FIFA 11 for PlayStation 3
Missing file on install
My fifa011/Support/EAHelp/Cz/EA_Help_UK.LOG. is missing i how can i recover it from harddrive
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
BOOTMGR is missing
Hello your windows system is damaged, or the harddrive is failing.
You need to install windows again, to make the pc running again.
The other solution is to use a rescue cd, and try to repair windows
It can be downloaded here:
http://www.hiren.info/pages/bootcd
When downloaded burn the iso file to a disc, and let he pc boot from it.
With the programs on the disk you can save some of you files on the harddrive, if its not damaged.
Typical bootmgr missing is caused by virus and trojans, or a failing harddrive.
I can`t give you a guaranty this will work, but a new install of windows will.
Here is the ASUS homepage:
http://support.asus.com/download/options.aspx?SLanguage=en
You will need this site for the drivers, for the mainboard.
Just enter the mainboard number.
The files from the site needs to be unziped before you install them.
Hope this will help you
Apr 14, 2013 | ASUS Computers & Internet
Unable to continue installing ea cricket 2007. error : audio\pbp.big file not found.
There is a possible solution involving copying the entire contents of the disc/s to a location on your harddrive and installing from there, but since I don't know the state of the disc/s in question, then it's just a suggestion.
Hope that helps.
Cheers from NZ
Jun 05, 2011 | EA Sports Cricket 07 for Windows
My computer is missing important system files
> type the path ...
Specify: C:\WINDOWS\ServicePackFiles\i386
as the "path".
Jun 23, 2010 | Computers & Internet
My computer crashed. I had it fixed and when I got it back sims 2 double delux was gone. Cant't find my access code or manual to reinstall. I have all the games that go with this program and now can't play...
Wow, that sounds bad. EA prints the access codes on the manuals and I think each game disc has it's own code. If you registered the games you might be able to contact EA and recover the codes or get new ones.
Have you tried using a code from another game disc? It probably won't work but it won't hurt to try. I have double deluxe and most expansions.
Try contacting ea at http://support.ea.com
in the uk try http://eauk.custhelp.com
or call them US (650) 628-9025
UK (0870) 2432435 if you don't mind paying for the call
Jan 31, 2010 | EA - Electronic Arts The Sims Double...
When i m playing ea sports cricket 2007 then there is written missing texture on every thing like bat on player ............so please help me when i am starting the ea sports cricket2007 game ,it is...
even i had a problem like that. i]this problem comes when your system needs more requirement to play this game or if the game is not installed correctly.
i installed another setu and got the game.
try intalling from some other setup file. or else update your ram and videocards
Jun 01, 2009 | EA Sports Cricket 07 for Windows
Missing some .Dll file
If you have the CD that came with the PC you can boot to it and run the repair option.
Dec 24, 2008 | MSI MS-1022 Notebook
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hard disk formet
Formating harddrive doesnt mean you already lost your data. It is being converted into binary file so there is possible to recover. The problem is you need to buy a data recovery to recover all the data lost in your harddrive.
I can help you but you need to buy the recovery for $99.00. Gurranted money back if the problem did not meet your requirements.
Rate me SOLVED!
Philip
Nov 19, 2007 | Computers & Internet
FIFA 11 for PlayStation 3 Logo
43 people viewed this question
Top FIFA Video Game Consoles & Games Experts
Kyocera HP Expert
marvinduran
Level 1 Expert
Are you a FIFA Video Game Console and Game Expert? Answer questions, earn points and help others
