Machine error panasonic
I have an error code on a NA-168VX4 washer
blueextc3221
  • 15935 Answers
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 19, 2010
SOURCE: Please I have got error
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
richroth
  • 9472 Answers
SOURCE: The error code U12 shows
The "U12" is due to the magnet that is attached at the tip of the lid. the magnet acts as a sensor that give info whether the lid is closed or open. Either the magnet has come off or it is not aligned properly.
Posted on Jul 31, 2011
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
My panasonic waching machine model is NA F80B2 Error is U 11 U 14
See http://www.manualslib.com/manual/783539/Panasonic-Na-F78b2.html?page=13#manual
Feb 06, 2015 | Washing Machines
My Panasonic top loading washing Mch model NA-F70G5 has no lite or power tks
In most cases ,problem is main control board on most front load washer
Oct 03, 2014 | Panasonic Washing Machines
What is Error Code H44 on Panasonic Washing Machine?
sad to say there is no H 44 listed o the 4 places I looked
Jun 17, 2014 | Washing Machines
Please I have got error code H 43 on display monitor of Panasonic washing machine model NA-14VX1, If you please may I know what is meaning this code and where is the problem. Thanks in Advance
Feb 05, 2011 | Washing Machines
Got error code u11
Mar 12, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
