Jindara wood heater
Smoke coming out door not drawing
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Wood burning heater when putting
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
Posted on Nov 02, 2010
  • 44271 Answers
SOURCE: I am getting smoke coming out of the pipe at the wall plus when you open burner door to load wood it bellows smoke out ! Please help
the chimney (flue) is blocked
check for blockage at the outlet or in the pipe
Posted on Dec 21, 2015
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Smoke comes out of draft vent and everywhere when starting a fire
Ugh, my husband does this... You have to start the fire so that it does burn hot enough to force the smoke up the chimney (and, yes, make sure the chimney valve is open!). To do this, keep building the fire in baby steps: light with balled up paper beneath a "teepee" of kindling and keep the door open. Once enough kindling is burning, add a couple pieces of larger wood (make sure all is very dry, especially to start) and start closing the door, but make sure the vent is open all the way. Once the wood is burning, add a couple more larger pieces and begin closing the vent - a little at a time, checking every few minutes. No, you don't have to stare at it the whole time, but keep checking. After awhile, you can fill the stove with very large pieces of wood and have the vent closed far enough to lower the flames to very small - but not to smothering totally. This is where the heat really starts and your room gets warm!
Mar 06, 2015 | Home
Norseman wood heate
do not turn that on again its too dangerus because maybe explode another time you turn it on
Jun 02, 2013 | Heating & Cooling
I have a very old franklin cast iron with consantina doors we we can,t seem to get enough draw and it smokes up the house we had the chimney cleaned and did,nt make any differance
I always found that if you put a sheet or two of newpaper up into the flue and light that when you are ready to light the fire, that it gets the draw going and it will stay that way. BUT you need to check the seals on the doors because if they are closed you shouldn't get much smoke.
Aug 03, 2011 | Franklin Heating & Cooling
I have just lit a coal fire for the first time in the living room, all is OK ecept when I went into the bedroom (2 floors above) I could smell smoke quite badly Any advice?
The chimney needs to be 3 feet taller than the highest point of the house . If you are running the clothes dryer, bathroom vent fan, or exaust hood in kitchen it makes a vacum in the house that can draw smoke into the house down the chimmney . I think when you burn wood or coal in a house it is pretty hard not to be able to smell it. Our house and clothes do not smell like smoke any more since we stopped burning wood.
Feb 02, 2011 | Heating & Cooling
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
Wood burning tips
-from the web
Nov 02, 2010 | Heating & Cooling
I purchased an aqua star 1600h-lp to be installed in a cottage. Question is, the cottage is heated with a large wood stove/fireplace. The water heater is located in a bathroom at the other end of the...
I would say that the wood fire/stove must have a heck of a draw to affect the bathroom heater. Maybe a separate air supply from outside via a pipe,to the stove meshed off against vermin would decrease the problem. Plus it could stop cold air being sucked across the room from an outside door.
Downdraft through the heater could happen with either vertical or horizontal vent. More important is the direction of the prevailing wind [horizontal] ingress of water/snow etc [vertical]
We often use the separate air supply in the UK and if the pipe bore is large enough 4" plus it seems to work ok.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
