Question about Motorola Mobility Defy Mini XT320 Black Android 2.3 SIM Free / Unlocked
Invalid battery - Motorola Mobility Defy Mini XT320 Black Android 2.3 SIM Free / Unlocked
When i start up the phone its shows invalid battery but i replaced new battery still it not works
1. connect your charger and wait about 1 hour (off position)
2.turn on your phone
3. pull out battery
4. put battery back and push battery until connect with the socket battery
5. if it doesnt work doit step (2.3.4) until show charging note
ps: it work on my motorola v6 ferrari edition
Apr 27, 2012 | Motorola Mobility RAZR V3i Cellular Phone
Handset reads Invalid battery
remove battery from phone;
wipe the battery pin and the phone socket with wet cloth now insert again and try
Apr 15, 2010 | Cell Phones
Invalid battery
The battery is probaly no longer capable of holding a charge, you can get a replacment Motorola V170 battery here - Motorola V170 battery
Apr 13, 2009 | Motorola Mobility V170
Motorola
REMOVE BATTERY > Clean the terminals specially middle terminals of both battery&phone with dry cloth.install battery. If the problem persist then change battery.
Mar 27, 2009 | Motorola Mobility L6 Cellular Phone
INVALID BATTERY MESSAGE
it may mean that you do not have the correct battery inserted in the phone....or the battery may be corroded
Feb 26, 2009 | Motorola Mobility L6 Cellular Phone
Motorola invalid battery
Do this and see if this works
Pull out the battery when the phone is turned ON(remove the battery when the phone is working.)
wait for like 15 to 20 seconds
Put the battery again and turn the phone ON
Jun 07, 2017 | Cell Phones
"invalid battery" and wont switch on
my motorola fon L6 is invelid battery plise find my recuest
May 27, 2008 | Motorola Mobility L6 Cellular Phone
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Battery
why does my fone say invalid battery?
Nov 01, 2007 | Motorola Mobility V551
Motorola Mobility Defy Mini XT320 Black Android 2.3 SIM Free / Unlocked Logo
197 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
