Question about KitchenAid KPES100PM Espresso Machine
Gasket How to change group gasket
  • KitchenAid Master
  • 1,267 Answers
Undo the screw in the middle of the grille where coffee is brewed, under that there are 2x allen head screws. Take them out and lever that circular aluminium disk vigorously until it comes free. It will be very very tight, once you have it out you will be able to lever out the huge group gasket. Clean everything and reassemble, holes in that aluminium disk will be quite blocked and may need to be drilled to clean them. Don't do the grille screw up too tight, it only makes it harder next time.
Posted on Dec 06, 2013
Replace group head seal ascaso ARC
Hi There, If you need a group gasket for the ascaso Arc
Try links below. If machine is the older model Ascaso gasket kit Dream Arc Basic If made after 2012 Ascaso group gasket Set 2012
Jan 04, 2013 | Ascaso ARC Dark Black Espresso Machine
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
Water is leaking around the edges of the basket and into the shots. Is this an o-ring gasket or a group gasket issue?
Group gasket issue, depending on the age of the machine the gasket might be dirty, use a Q-tip or your group brush to clean, if machine has over 2 years use then replace group gasket.
Sep 02, 2010 | Gaggia Carezza Espresso Machine
One one has removed the two allen bolts holding the `group in a Coffee Gagia, how does one remove the group holder to get to change the large gasket?
All you need is another gasket then use an ice pick or a scratch awl and remove the old gasket, it might come out in pieces.
Mar 12, 2010 | Coffee Makers & Espresso Machines
How do I replace the group gasket?
1. empty the water tank
2. turn machine upside down
3. remove shower rose(one screw in middle)
4. remove group head (two hex screws)
5. pry out old gasket
6. fit new gasket and reassemlbe
Dec 25, 2009 | Gaggia Classic Espresso Machine
ECM Giotto group gasket and shower plate falling out
I am assuming that you have basket style shower which sits in the gasket and then inserts in the group.
Find the small bevel edge on the gasket, make sure that side is facing up, place gasket on table then insert shower in gasket, then lift gasket, until it sits at the top of the shower(use a small flat screwdriver or a small hard brush to clean the group where the gaskets seats), then insert gasket and shower in group. Push in as far as you can then use the portafilter to seat the gasket in all the way.
If your shower is the flat style then there should be a hole in the middle for a screw.
May 29, 2009 | ECM Giotto Espresso Machine
Gaggia Classic Group Head Stuck
try this website http://www.bluebox.com.au/jcrayon/gaggia/
Mar 06, 2009 | Gaggia Classic Espresso Machine
Leaking around the group
Go to coffeegeek (dot) com and do a search for gasket replacement...they will tell you EXACTLY how to do this. This is an EASY fix! (Good Luck)
:o)
Oct 20, 2007 | Nuova Simonelli Microbar Espresso Machine
KitchenAid KPES100PM Espresso Machine Logo
47 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
